Keys
Old Feb 11, 2015 | 09:27 PM
mossmotors's Avatar
mossmotors
Cruising
Default Keys
Kays locked in 2006 c6 corvette hatchback.is i pressed the black button to make hatch open but it didnt
Old Feb 11, 2015 | 09:33 PM
Vette_DD's Avatar
Vette_DD
It didn't because you have to have a fob that's programmed for the car on the outside of the hatch near the black button you press to enter the hatch. Not really a good reason you should have locked both fobs in the rear hatch.
You need to get the Chevy dealer to cut you a key for the rear hatch. You'll need a the car's VIN and I'm not sure what else, maybe some ownership papers.
Old Feb 11, 2015 | 09:34 PM
RicK T's Avatar
RicK T
Only one set? No 2nd or emergency key somewhere?
I'm talking about a key, not another FOB.
Old Feb 11, 2015 | 10:43 PM
owc6's Avatar
owc6
If you don't have another fob, and, or key, you are (most likely) SOL, w/o getting a key cut at a dealer using the VIN.
Probably your best bet is the vin and dealership method to get a new key cut. Then get another fob and key and program it so you aren't left in the lurch, again.
Old Feb 12, 2015 | 06:10 AM
Dano523's Avatar
Dano523
The key works by it's mechanism cable pulling on this latch on the hatch locking mechanism inside the car trunk area,
So T-15 to remove the passengers inner tail light to get to wire grommet, push the wire grommet in the pass through channel to give you access through the grommet channel, and a tool to push the tab over to the right that the cable is connect to through the grommet hole to open the hatch.
Once you are in, then put a little dielectric grease on the wire grommet and reset it back in the pass through channel.
Or the easier/faster way that most tow truck drivers use, small wedge to wedge the window away from the glass seal without breaking the glass, and just hook a wire on the door manual unlock on the floor of the car to open one of the doors instead.
Bottom arrow
To Keys
