New to the forum had trouble with the Harmonic Balancer on 07 Tues Mon my car went into limp mode got it to the dealer they could not find a problem reset that afternoon car started squeaking it was the Balancer coming apart has this happened to anyone ekse
Yes, it has. Google: Harmonic Balancer Corvette Forum.
You'll find plenty of information.
Not a big deal to get it fixed. Most recommend using a non GM replacement unit.
Not a big deal, hummmm. How about the $8-1200 to fix it. Removing the rack, radiator, realignment of the front end, etc, etc, etc.
I bought mine knowing the balancer was bad. After research here it seemed like part of owning a C6. Was not a big deal to me. Steering rack has to be moved out of the way but removal is not required. Radiator stayed in place. Use an aftermarket balancer (I used and ATI) or you may have the same problem again.
I bought mine knowing the balancer was bad. After research here it seemed like part of owning a C6.Use an aftermarket balancer (I used and ATI) or you may have the same problem again.
^this^
As to the "no big deal part" I'm sure it's true if you can do it yourself, if not, it will make you about 1k poorer, more or less.
Definitely go ATI if you can. Best HB out there, but there are some other brands with very well built ones too, like Powerbond.
Welcome to the C6 world!
