Lift Installed
Moderator
Received 3,589 Likes
Lift Installed
I moved from North Carolina to Florida the end of 2014 and finally got my lift installed in the new home
Nice! It looks like about a 9-10' ceiling. I assume you had to convert your garage door to a high-lift and install a jackshaft opener. I can see the door track for the adjacent bay is at a more typical height.
How was your breathing as you watched your beautiful car being lifted off the ground. I don't think I breath until the car has settled on the proper height. Check the dogs as you raise the car and when you are at the desired height make sure the dogs are high enough so that when you lower it they get fully seated. I check all four to make sure they are properly seated.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Looks very good, John. The Orange (Sunshine) State welcomes you both and your garage lift!
Moderator
Moderator
Moderator
Moderator
