Wild 2 Mild Controller
Old Feb 23, 2015 | 03:20 PM
BurgundyVette's Avatar
BurgundyVette
Default Wild 2 Mild Controller
How many members have their Wild 2 Mild Controller installed the "ZERO
drain" way (fuse plugged into the seat heater), or the normal way?
Does it really matter, since we all use a battery tender, when the car is siitting for long periods of time.
Old Feb 23, 2015 | 03:58 PM
Oskee's Avatar
Oskee
Veteran: Marine Corps
I have mine wired the normal way and just make sure its turned off before shut down (flaps open) then plug in the battery tender
Old Feb 23, 2015 | 04:22 PM
maustin195's Avatar
maustin195
Mine was wired the zero drain way from the beginning. I cant comment on the original way but mine sat for over a month without a charger and had a fully charged battery.
Old Feb 23, 2015 | 04:23 PM
Vette_DD's Avatar
Vette_DD
Mine uses the seat heater fuse, and I've never needed to use a battery tender in the 10 years I've owned a C6.
Old Feb 23, 2015 | 04:27 PM
Homer3D's Avatar
Homer3D
I have mine installed the normal way because the seat heater fuse is being shared with my curb alert. I do use a battery tender if I don’t plan on driving my C6 for more than a week.
Old Feb 23, 2015 | 04:29 PM
acheman8's Avatar
acheman8
I'm not sure what the "normal" way is. I simply routed the fuse for the valves to a rocker switch wired under the dash. I've never used a tender and in the three years I've owned the car, I've only driven on the weekends. No battery issues yet.
To Wild 2 Mild Controller
