Tachometer Problem
Old Mar 1, 2015 | 03:28 PM
Mike08's Avatar
Mike08
2nd Gear
Default Tachometer Problem
I have a 2008 M6 and now my tachometer doesn't move at all it just sits at 0rpm does anybody know what could it be?
Old Mar 1, 2015 | 05:16 PM
Rebel Yell's Avatar
Rebel Yell
Wish I could help you Mike. But, I will get you back to the top of the page with this post. Good luck.
Old Mar 1, 2015 | 05:22 PM
extrapilot's Avatar
extrapilot
Sounds like a reboot of the ECM is in order, discount the battery for minute, reattachment, and don't forget to re-index the windows.
Sometimes this is a fix all to electrical issues.
GL
Old Mar 2, 2015 | 02:36 AM
Dano523's Avatar
Dano523
GL
This, or could be a loose/corroded connector on the gauge pod.
The dash gauge pod is easy enough to pull out of the dash to check the connectors, and even to check for a cold solder joint on the board as well once you have it out of the dash.
Old Mar 2, 2015 | 07:06 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If you have a HUD the same signal operates both and would eliminate about half the connections and components if the HUD still worked or didn't. My first guess would be the servo motor in the dash. But, without more information, at this point everything is just a guess.
Old Mar 2, 2015 | 12:37 PM
Mike08's Avatar
Mike08
2nd Gear
The HUD still works it's just the tachometer that doesn't
Old Mar 2, 2015 | 12:46 PM
Spark 2's Avatar
Spark 2
St. Jude Donor '07-'08-'09
Private Message Sent!
Old Mar 2, 2015 | 05:25 PM
Dano523's Avatar
Dano523
Cold solder joint on the dash pod board most likely the problem.
Old Mar 4, 2015 | 07:05 AM
FortMorganAl
If the HUD reads rpm then that leaves only the dark green/white wire on pin 6 of the instrument panel connector C2 and something on the panel itself. There are 2 16 pin connectors. C1 has the dark green/white wire on pin 16 which is in the corner. C2 (the one you want) has it on pin 6 which is the third wire over. I'm still leaning toward the servo stepper motor but at least it has been narrowed down to the panel itself or the wire to the panel. A dealer is just going to replace the whole panel which is going to be expensive. I think the next step is to remove the panel and see if you can trace the wire to the logic circuit and from the motor to the logic circuit. The digital logic is probably not the issue since the other gauges still work.
Old Mar 4, 2015 | 09:28 AM
87SAM's Avatar
87SAM
Not sure how it pertains to a C6, but on a C5 the needle on rare occasions would actually become loose on the shaft and just sit there and not move.
To Tachometer Problem
