Help L.E.D. resistors
Old Mar 3, 2015 | 02:36 PM
king off the hill's Avatar
king off the hill
Default Help L.E.D. resistors
Hi guys keep blowing resistors on turning lights , Please any ideas,Thanks
Old Mar 3, 2015 | 02:40 PM
king off the hill
ps changed from bulbs to led.
Old Mar 3, 2015 | 06:30 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Yup, same here; I finally doubled up and run two on each side so that each resistor is carrying half the load. So far so good; has been over a year without having to replace anymore.
My next step (should I burn out anymore) will be to mount the two resistors on an aluminum plate and mount the plate on the wheel side of the access cover. This way it will have air flow from the front wheel.
Good luck
Old Mar 3, 2015 | 06:45 PM
KB9GKC's Avatar
KB9GKC
Hello,
Use higher wattage resistors!
You can get them from Digikey or Mouser
Douglas in Green Bay
Old Mar 3, 2015 | 10:15 PM
hisvett's Avatar
hisvett
Originally Posted by KB9GKC
Hello,
Sounds feasible but that's not how it works. It takes 50 ohms of resistance to make up the difference between the LED replacement bulb and the standard OEM bulb so the blinker will not Hype-flash. Adding more resistance will only slow down the blinking and not lessen the heat generated by the resistor.
By using two resistor's in parallel, each resistor will only need to handle half the total load (heat) while still giving a total of 50 ohms of resistance.
I found it best to crimp the wires on to the resistors, not solder. The heat from the resistor will soften the solder enough to loose connection. Hope this all helps
Old Mar 3, 2015 | 10:40 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Unfortunately, the resistors installed on the front turn signal LED's are "on" when the lights are in DRL mode. That is when the turn signals are on constantly and consequently, the resistors will get very hot.
I have 6 ohm, 50 Watt resistors for each of my rear turn signals/brake lights. They have integral finned aluminum heat-sinks.
They are mounted to small aluminum plates with an air-gap underneath. The plates are bolted to a piece of canvas phenolic (pic 1).
The phenolic panel/resistors are then bolted to the inner, rear tub (pic 2).
All four resistors are grounded to the rear ground point directly below the passenger side tail lights (pic 3).
The resistors and aluminum plates are from V-LED's and the phenolic panel is from Grainger.
I would suggest something similar in the front with the resistors/etc mounted in the engine compartment where they will be exposed to more air-flow.
Old Mar 3, 2015 | 11:02 PM
Knob Jockey
Here's the Ohms Law Pie Chart.
This will help you see the relationship between the resistance of the lighting circuit versus the wattage and voltage.
For Watts use E squared divided by R to determine P. E = Volts, R = resistance in Ohms and P = Watts.
The OEM lamps in the C6 draw around 26-28 Watts at around 13 Volts.
The 6 ohm resistors I used draw about 25 Watts. Not a perfect match, but close enough to fool the BCM.
Their 50 Watt rating is more than high enough to dissipate the load and associated heat.
Old Mar 4, 2015 | 12:14 AM
Tropicana's Avatar
Tropicana
Jees, if Chevy would have just given us LEDs to start with...
Old Mar 4, 2015 | 07:57 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Hello,
Then install them as they were intended to be installed on heat sinks. All those little fins are trying to get rid of the heat but you are putting them near a several hundred degree heat source so you need more cooling. Adding several resistors in series and/or parallel with values calculated to be the same as a single resistor will help by sharing the heat but mounting on a large heat sink will be a lot less expensive. Be sure to also use heat sink (silicone ) grease.
Old Mar 5, 2015 | 05:18 PM
KB9GKC's Avatar
KB9GKC
Hello,
That is how it works my friend. I did not say add resistance, I said a higher wattage resistor was needed (or heatsinked resistor).
If you place two 50 ohm resistors in parallel you have 25 ohms but twice the wattage.
Solder flows at 600 + degrees, if you resistors are becoming desoldered you have a problem.
Hope that helps,
To Help L.E.D. resistors
