Low profile floor jack
Old Mar 4, 2015 | 11:37 AM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Default Low profile floor jack
I am sure this has been addressed before, but I cannot find a good answer. I am looking for an in expensive, low profile floor jack that will work on my C6 and (hopefully a C7.) I do not want a scissor jack and I do not want to spend $500.00 on a jack I would use maybe twice a year.
I recently had to remove the front tire off of my C6 and with my standard floor jack I could only get it under the rear jacking point (not the front one) and even then I was unable to use the jacking pucks. I was careful and did not damage the rocker panels.
Suggestions are welcome on a type of jack that will work as well as a source for the jack.
Old Mar 4, 2015 | 11:42 AM
tjwor's Avatar
tjwor
Harbor Freight seems to be the consensus around here. A few different low-profile jack options.
http://www.harborfreight.com/3-ton-l...ump-62326.html
http://www.harborfreight.com/2-ton-L...ump-68050.html
Old Mar 4, 2015 | 11:43 AM
Jeff-Ford's Avatar
Jeff-Ford
I bought one from Home Depot. Husky 2 Ton Aluminum Racing Jack Model # HD00110 and it works great for 180.00
4000 lbs. capacity
Lifting range: 3.5 in. to 16.5 in.
Meets ANSI 2009 standards
Dual pump design
4 in. rubber saddle pad
Rear swivel casters for easy maneuverability
Foam padded handle to prevent damage to vehicle
Old Mar 4, 2015 | 11:55 AM
Don-Vette's Avatar
Don-Vette
Harbor freight.
Old Mar 4, 2015 | 12:24 PM
Seadawg's Avatar
Seadawg
Originally Posted by Don-Vette
Harbor freight.
Old Mar 4, 2015 | 12:25 PM
mysloride's Avatar
mysloride
Northern Tool has a aluminum low profile 1.5 ton jack on sale for 79.99
I just bought one and am using it to put my track tires on my lowered 2011 GS...it works great
Old Mar 4, 2015 | 12:32 PM
surfinva27's Avatar
surfinva27
+1 for the harbor freight jack. Bought it not too long ago but it has worked great so far, and much cheaper than many others.
Old Mar 4, 2015 | 12:33 PM
dennis50nj's Avatar
dennis50nj
Do yourself a favor, just drive up on some 2"x12"' boards then put the floor jack that you have under the front and jack it up
Old Mar 4, 2015 | 12:36 PM
jrose7004's Avatar
jrose7004
I got this one.
http://www.harborfreight.com/3-Ton-A...ump-68052.html
Old Mar 4, 2015 | 12:54 PM
Not So Fast's Avatar
Not So Fast
I'm looking to buy from Harbor Freight when they open their new store in little ole Havasu next month low profile long reach!!
But I don't expect to be able to jack up the Vette front end without my home made 2X10 ramps and cradles, just to low, unless it's a single wheel lift then use pucks.
Side note: anyone have an opinion on oil vs oil less air compressors, they have a nice portable 8 gal on sale right now that I'm thinking about getting, been using a lot of air lately and the little one I have just doesn't cut it.
NSF
Old Mar 4, 2015 | 12:56 PM
boraxman's Avatar
boraxman
Have the cheap aluminium from Harbor freight...Been great for the last 4 years.
Old Mar 4, 2015 | 02:42 PM
HBsurfer's Avatar
HBsurfer
I have the Harbor Frieght 3 ton and love it. It will not reach under the front end to raise it from the the center. Still need to drive up on a 2X. It will reach under the rear for single point lift. I never put stands under the lifting pucks. To me it seems unstable, like any small movement would allow the puck to slide off the stand. Too smooth a surface to use here in earthquake county. I alway put mine under the car at the GM suggested support points.
Old Mar 4, 2015 | 02:59 PM
Eritosthenes's Avatar
Eritosthenes
Fast
Good
Cheap
Pick two.
On that note, the best low-profile long-reach floor jack for the C6 is undoubtedly the Omega/Blackhawk 29023 (about $390 + shipping). This 125 pound beast slides easily under jacking pucks installed in the frame slots in the rocker panels. No 2x12 drive-on boards are required. The Omega can be fitted with a crossbar and rolled under the nose of a C6 all the way to the designated lifting points without contacting the front fascia. As far as I know, no other jack can do this.
Short of a 2- or 4-post lift, possibly the only better C6 lifting device would be the Bendpak/Ranger BL-5000 Quick Jack ($1,295 at Summit Racing).
Old Mar 4, 2015 | 08:31 PM
cmonkey713's Avatar
cmonkey713
Harbor Freight has several to choose from. the small aluminum 1.5 ton will work fine and for $59 to $79 you cant beat it. Look for a HF discount add in any automotive magazine for the sale price. Don't forget to use jacking pucks.
Old Mar 4, 2015 | 09:09 PM
usdmpwr07's Avatar
usdmpwr07
I have a harbor freight jack, can't complain.
Old Mar 4, 2015 | 09:11 PM
biker1059's Avatar
biker1059
Harbor Freight, 68050, its the longest they carry. Works well.
Old Mar 4, 2015 | 10:39 PM
jbc1995fb's Avatar
jbc1995fb
+1 for harbor freight.
To Low profile floor jack
Old Mar 4, 2015 | 10:47 PM
Wampa's Avatar
Wampa
<---- another happy harbor freight jacker
Old Mar 4, 2015 | 11:03 PM
stroked383z28's Avatar
stroked383z28
Arcan XL35 from Northern Tool here. Had it for many years...works great.
Old Mar 4, 2015 | 11:14 PM
crawfish333
CI 6-7 & 9 Veteran
Thanks guys!
