Removing side fender emblems.
Old Mar 7, 2015 | 10:22 AM
Ahzuz's Avatar
Ahzuz
Default Removing side fender emblems.
Hello everyone,
I'd like to remove my side fender emblems (circled red in the picture), one has the colors washed away so i think it would look cleaner without them.
My car is stored away so I can't look closely but is it just "glued", it will come off with a heat gun or I have to go under the fender to de-screw ?
Thank sfolks
Old Mar 7, 2015 | 10:29 AM
wayback's Avatar
wayback
Looks aftermarket so it should just be held on with doublesided tape.
Take some fishing line and "saw" through the tape. Then the rest should come off pretty easy.....might need some goo-gone to remove all the adhesive.
Old Mar 7, 2015 | 10:32 AM
Ahzuz's Avatar
Ahzuz
The sign says "LS2" , it was there when I bought the car, most likely aftermarket unless GM Shipped some 2007 with LS2 badges ?
Old Mar 7, 2015 | 10:52 AM
wayback's Avatar
wayback
No they did not. Deff. aftermarket.
Old Mar 8, 2015 | 09:23 AM
KBsToy's Avatar
KBsToy
I took of my emblems. It was cold in the garage so I put my portable heater by it let it warm up a bit then used fishing line to get behind and cut it off. I then used WD-40 to clean-up residue glue. Took about 10 mins for both
Old Mar 8, 2015 | 02:00 PM
mpuzach's Avatar
mpuzach
Good call to take them off.
Old Mar 8, 2015 | 05:08 PM
windyC6's Avatar
windyC6
Be sure you keep pulling outward on that fishing line while sawing. Lot better off removing more glue then repairing the paint.
Old Mar 8, 2015 | 06:19 PM
Ahzuz's Avatar
Ahzuz
Call me stupid but it's safe to use WD-40 on the paint ?
That's what i'm scared of.
Old Mar 8, 2015 | 07:53 PM
wayback's Avatar
wayback
WD 40 won't hurt the paint. Neither will fishing line. I have taken the front, back and chicklets off several times. No problems.
Old Mar 8, 2015 | 08:19 PM
KnightmareCS's Avatar
KnightmareCS
Amazon.com: 3M 03618 Adhesive Remover - 12 oz.: Automotive Amazon.com: 3M 03618 Adhesive Remover - 12 oz.: Automotive
Old Mar 8, 2015 | 10:59 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
If you need heat, you'll probably be better off using a hair dryer instead of a heat gun. Heat guns can get too hot and damage the paint. And a hair dryer should soften the adhesive up nicely. After you get the goo off, just buff it and wax it and you'll be good to go.
Old Mar 8, 2015 | 11:03 PM
acheman8's Avatar
acheman8
Use a hair dryer on it for a few minutes. Put you hand beside the emblem and heat it up. If your hand gets uncomfortable, its getting too hot. Keep the dryer moving. Instead of fishing line, I suggest dental floss -- the flat tape kind. Work slow and move the floss back and forth. Should pop right off. WD-40 will clean up the goo and will not harm the finish.
Ultrasport05's Avatar
Ultrasport05
Be careful using fishing line. It can scratch the paint. I use a heat gun turned on low and some dental floss. Works well enough
To Removing side fender emblems.
