Small rocks stuck ...
Old Mar 9, 2015 | 01:36 PM
Anselmo Moreno's Avatar
Anselmo Moreno
Default Small rocks stuck ...
I was detailing my car and found some small pebbles just embedded at the bottom of my driver's side by the rear wheel...I believe it would be the quarter panel?
Anybody else had this issue? What would be the best way to remove these without damaging the car. The passenger side does not have any of these little rocks, just the driver's side.
Old Mar 9, 2015 | 01:41 PM
wayback's Avatar
wayback
Need to loosen the screws to remove the pebbles. Once clean you can put some 1/4 in open cell foam weatherstrip between the panels. Open cell is the one that is easily compressed.
Common problem. You might even be able to close up the panel gap. Is it the same on both sides? I bet not.
My 07 has never had this problem, and I am at 146,700 miles of smiles.
Old Mar 9, 2015 | 01:44 PM
EVRose's Avatar
EVRose
https://www.corvetteforum.com/forums...ml?forum_id=74
Old Mar 9, 2015 | 01:54 PM
raspyc6's Avatar
raspyc6
I have the same problem and I hate it.
Old Mar 9, 2015 | 01:57 PM
airmed2's Avatar
airmed2
Good call on the weather strip. I'd use a compressor / air hose / air chuck and blow them out.
Anselmo Moreno
Big thanks for the link EVRose! I tried searching but was a bit lost on what to search for...
Old Mar 9, 2015 | 02:07 PM
EVRose's Avatar
EVRose
"Rocks In Rockers".
Old Mar 9, 2015 | 02:19 PM
Don-Vette's Avatar
Don-Vette
Been there done that. ..
Old Mar 9, 2015 | 02:37 PM
funymuny's Avatar
funymuny
Well-known issue/design flaw. Loosen panel from inside wheel well to create enough space to remove debris. I tried insulation strips inside fender to 'seal' the space where debris enters. I had moderate success.
Old Mar 9, 2015 | 04:10 PM
CHEV AGAIN's Avatar
CHEV AGAIN
I loosened the bolts holding the rocker panel on and pulled it down and banged on the fender until the gravel was done raining out. I don't believe it is getting in from the outside, it's getting in behind from somewhere the wheel well doesn't seat well.
Old Mar 9, 2015 | 04:20 PM
blittle's Avatar
blittle
Hmmmm.....just went and looked at mine and don't have any of that....and I drive the car, its not a garage queen. .....wonder what the difference is....mine is a 12 GS.
Old Mar 9, 2015 | 04:23 PM
CHEV AGAIN's Avatar
CHEV AGAIN
mine seems to be a sample of the thousands of yards of sand/gravel they put on our roads all winter. That they don't seem to get cleaned up until July..
Mark
Old Mar 9, 2015 | 04:53 PM
airmed2's Avatar
airmed2
My GS doesn't exhibit that problem either. Not one pebble.
Old Mar 9, 2015 | 05:11 PM
zero11's Avatar
zero11
I had it on my 011 ,I used a tooth pick and worked them out .not to hard it worked for me
Old Mar 9, 2015 | 06:11 PM
funymuny's Avatar
funymuny
They do get in from the inside of the wheel well.
Old Mar 9, 2015 | 06:17 PM
jovette's Avatar
jovette
I've had the same problem with both my '10 GS and now my '13 427 Convertible. Problem is worse on drivers side. I too have installed insulation foam strips in the gaps on the front side of the rear fender liners and it has help, but not eliminated the problem. These Michelin PS2s on my 427 are very sticky tires and really pick up the sand and small gravel........... simply amazing the amount of sand and small rocks that comes out of that area after taking out the screws and banging the side of the rocker panel
Old Mar 9, 2015 | 06:24 PM
61X's Avatar
61X
Be very careful when washing your car. If you pick up some of that debris with your wash mit or rag or whatever you use it could be ugly.
To Small rocks stuck ...
Old Mar 9, 2015 | 06:36 PM
Not So Fast's Avatar
Not So Fast
WHEW, I thought what the hell when I first noticed this after getting the car home. I started seeing these little pebbles falling out on the floor of the garage. I tapped the side right above the area and they kept coming, pretty big pile like in the photo. Believe I got most out but I will be doing the insulation trick ASAP
Thank you again FORUM MEMBERS!!!!!!!!!!!
NSF
Old Mar 9, 2015 | 06:43 PM
MTsVette's Avatar
MTsVette
From: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
I just give the quarter panels a light tap and most come out...
MT
Old Mar 9, 2015 | 09:53 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Some people use insulation foam instead of the strip. Rocks come off the tire at the top of the wheel well and work themselves down. If you undo the nuts holding the body panel and shake it, it usually drops most of them.
