The Offical: C6 Base/Narrow Body Aftermarket Wheels
Old 08-13-2019, 04:34 PM
  #321
car2fast4you
car2fast4you's Avatar
American Racing AR924 Crossfire
Front 18 x 8.5 - 55mm offset
Rear 19 x 10 - 75mm offset
They're inexpensive and very light.
rskwannabe (02-16-2021)
Old 08-14-2019, 03:23 PM
  #322
bullitt666
bullitt666's Avatar
My 05 with C7 ZR1 Wheels
Not4spd (09-20-2021)
Old 08-14-2019, 04:00 PM
  #323
Narddog
Narddog's Avatar
Z06 reps
Old 08-15-2019, 03:09 AM
  #324
O TAZ
O TAZ's Avatar
Old 08-15-2019, 08:04 AM
  #325
Jaime-Corvette
Jaime-Corvette's Avatar
Cray Spyder Gloss Black 18x9 - 19x11
Front 255 tires - rear 305 tires
FLUSH!!!
Old 12-13-2019, 10:32 AM
  #326
farbeyonddriven
farbeyonddriven's Avatar
Wheels - Varro VD01
Front 19x9.5 +53 275/35/19 Nitto NT555 G2
Rear 20x11 +73 305/30/20 Nitto NT555 G2
The following 3 users liked this post by farbeyonddriven:
13c5 (04-06-2023), scottg (11-09-2020), ST33N56 (05-22-2020)
Old 12-14-2019, 08:38 AM
  #327
Mikelofty
Mikelofty's Avatar
ZR1 reps
Old 12-15-2019, 01:57 PM
  #328
SteveSierra
SteveSierra's Avatar
Originally Posted by farbeyonddriven
Wheels - Varro VD01
these look amazing!!!
do the rears rub at all and have you got any closer pics to see if they stick out?
farbeyonddriven (12-15-2019)
Old 12-15-2019, 07:50 PM
  #329
farbeyonddriven
the suspension is set just right so they do not rub. If it were any lower it would be very close.
Old 01-07-2020, 07:24 PM
  #330
CrystalRedTed
CrystalRedTed's Avatar
Have you rubbed at all when cornering aggressively? Looks great but very tight.
Old 01-07-2020, 08:44 PM
  #331
farbeyonddriven
no rubbing at all
Old 01-07-2020, 09:06 PM
  #332
ColeJ5743
ColeJ5743's Avatar
no rubbing at all
Yeah my Verona’s put the wheel out about where these are. There is no rubbing, but there is no more room. I actually think I need to be very careful with tire selection and negative camber settings so that doesn’t change. You can have a tire with same nominal numbers (ie 295/30-20) but within that size, you’ll see some with a section width of like 11.9 and a tread width of 11.6 versus some that may have a section width of 11.5, and a tread width of 10.1. This kind of stuff can be the difference in rubbing or not rubbing when the offset puts the wheel and tire really close to the fender.
centennialGS (01-08-2020)
Old 01-07-2020, 09:16 PM
  #333
farbeyonddriven
I am pushing it about as far as you’d want to with my set up IMO
haberman13 (01-12-2020)
Old 01-07-2020, 10:28 PM
  #334
CrystalRedTed
no rubbing at all
Cool Thanks for the response. I just started running a very similar setup - a few mm less offset in front and 265 width tires. Max camber dialed in. So far it has been fine. Just a very very slight grazing turning into a steep driveway. I haven't done any track or autocross events with it so I don't know if there would be any rubbing under those conditions.
Old 01-12-2020, 06:37 PM
  #335
haberman13
haberman13's Avatar
Beautiful setup. These wheels are top of my list now, brushed silver, on Velocity Red
Old 01-13-2020, 12:11 PM
  #336
farbeyonddriven
Those would look good. I have actually been thinking about posting mine for sale on here and running the stockers. I have the car going in for a ecs novi, blower cam and supporting mods, LG super pro LTs and tune. We should be around 650whp, I dont wanna burn through these expensive *** tires lol
Old 02-12-2020, 04:01 PM
  #337
Jose A Ortiz
4th Gear
Jose A Ortiz's Avatar
Originally Posted by C6David
Here's the new wheels
Ruff Racing 954
Front 19x9 +50 245/35/19
Rear 20x10.5 +65 285/30/20
I wanted to get 295s out back but couldnt find any for a good price.
what's the offset in this wheels?
To The Offical: C6 Base/Narrow Body Aftermarket Wheels
Old 02-12-2020, 07:02 PM
  #338
Omega Doom
Omega Doom's Avatar
great thread and does anybody know if you can use the weld S77s or RTS wheels with Z06 brakes like will they clear? and the Forgestar F14s in 17s or especially the 18s front and back
Old 02-12-2020, 08:55 PM
  #339
Jaime-Corvette
17 for front is too small the big front brakes wont clear in diameter.you need 18 at least and even those will barely just fit. I have 18 front on my base with z06 brakes they are a paper away front touching the inner barrel of the wheel
Old 02-12-2020, 09:53 PM
  #340
Omega Doom
Omega Doom's Avatar
yea I know im running the TSW interlagos which have grown on me a bit but not my first choice just that they came with the car
Quick Reply: The Offical: C6 Base/Narrow Body Aftermarket Wheels
