fuel return
Old Mar 18, 2015 | 08:32 AM
curtisb23's Avatar
curtisb23
Default fuel return
so i ran out of fuel pump on the dyno yesturday with a upgraded dw300 pump ,it got me to 560hp on a mustang dyno, adding a return line would let the pump push more fuel ,but wile having the tank out ill probably go bingger on the pump .so wondering who has made there own fuel return? iv done so on my import an was easy.
guessing i need furl rails to start a fpr and some -6 steel line and fittings
witch side would you run the return line back into the driver or passsanger side?
thanks
