Anybody use a Fumoto valve ...
Old 03-18-2015, 04:31 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
Default Anybody use a Fumoto valve ...
... in place of the regular oil drain plug? Or do Vettes sit too low to the ground that an accidental opening of the valve on road debris would be too likely?
Old 03-18-2015, 04:52 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
i 've been using the fumoto oil plug for 2 years on my 013 base. that car is gone and in place of it i have a 012 CE GS that i just ordered a f107s oil plug for. i had a thread on this plug a year or so ago and got very little response. i think they're GREATTTTTTT and so easy to drain oil every time you change your oil. it's a spring loaded gizmo you push up and slide over to drain. slide the valve back and it locks into the closed position. and if your a little skeptical about that, they now have a plastic locking devise you can use. no more taking oil drain plugs off and replacing because these are on for the life of your vehicle.
Old 03-18-2015, 04:54 PM
FAUEE
FAUEE's Avatar
Received 4,505 Likes on 2,829 Posts
I have one on my daily driver. It works OK, but as time goes on it doesn't make the greatest seal in the world IMO. It leaks and drips a little now, but it's like 5 years old or more at this point.
Old 03-18-2015, 06:39 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
still not bad for a $30 dollar part.
Old 03-18-2015, 07:18 PM
EVRose
EVRose's Avatar
I have one on my wife's car and no leak so far after 2 years. I like it a lot. Don't have one on the C6.
Old 03-18-2015, 07:41 PM
montyred07
montyred07's Avatar
Default oil pan valve
I used the valve for the last 10 years no issues on the vet and the dd's The only draw back is I forget to replace the valve with the oem bolt when I sell the cars
Old 03-18-2015, 11:21 PM
HBsurfer
HBsurfer's Avatar
Received 1,110 Likes on 709 Posts
I have used them on all of my cars for at least ten years. Never had a leak or any other kind of problem. Makes oil changes a simple deal. I would not drive a car without it, low or not. If something came up and took out the valve on the Corvette it would tear off the oil filter as well. Not much chance of that happening anyway. Fantastic product. Used by a lot of race teams too.
Old 03-19-2015, 01:37 PM
njedwardz
Support Corvetteforum!
njedwardz's Avatar
I have one on my '13 and love it. Super convenient and no issues. The car is tracked occasionally and I haven't had any leaks or other problems.
Wish there was a way to change the oil filter without spilling any oil, because that's the only reason I really need to wear gloves anymore. (this is where someone chimes in with a great product that does exactly that, and I thank them profusely )
Old 03-19-2015, 01:44 PM
HBsurfer
HBsurfer's Avatar
Not totally clean but for al of my cars I have used a small center punch and poked a small hole in the bottom of the oil filter. Almost all of the oil drains and make filter removal a lot cleaner. On the Corvette, the drain plug and filter are close together and I can drain both at the same time
Old 03-19-2015, 11:52 PM
Vet Interested
Vet Interested's Avatar
Received 2,093 Likes on 1,207 Posts
Have one on my 2010 base for over a year now. No problems or leaks. It's the kind of product you forget you have until you go to drain the oil. Never causes a problem and does its job.
Old 03-20-2015, 12:09 AM
Torch Ace
Torch Ace's Avatar
I have one on both of my C6's.......It's the only way to go in my opinion.
Old 03-20-2015, 06:42 AM
Don-Vette
Don-Vette's Avatar
I like old school regular drain plugs. The only possible benefit I see with these is for lazy people and those who don't know how to properly tighten the plug. Lol
Old 03-20-2015, 07:19 AM
timvan
timvan's Avatar
Tool less oil changes, ability to attach a hose to drain oil are a couple of reasons alone. I dont have one on my vette, however I do on my DD and my diesel truck - great product
Old 03-22-2015, 02:25 PM
Viz
Viz's Avatar
I've used them for over 25 years, and some were on cars for over 15 years (I tend not to get rid of things). Never had a single leak, and I've personally never heard of one getting "accidentally" knocked open. I suppose with the right combination of circumstances it could happen, but I wouldn't worry.
Old 03-22-2015, 02:50 PM
KnightmareCS
KnightmareCS's Avatar
Don't the drain plugs have a magnet at the tip? It's quick/crude way of seeing the engine's life when you change the oil. Only feature I see you lose, but the valve's pretty nifty.
Old 03-22-2015, 03:27 PM
Bazinga
Bazinga's Avatar
Hammi, get off of Don's computer!!
Old 03-22-2015, 04:48 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
i bought the magnet that goes right on the oil filter so it doesn't matter when i use the fumoto. actually, i think the magnet on the oil filter is much more productive in retaining little metal particles.
To Anybody use a Fumoto valve ...
Old 03-22-2015, 05:23 PM
KnightmareCS
^ That's a good solution.
This makes it a no brainer all around. I always end up fumbling the plug into the pan
Old 03-22-2015, 05:42 PM
easyrider13
easyrider13's Avatar
I installed on at the first oil change of my 2005 C6.
It has worked well with no issues.
Old 03-22-2015, 06:22 PM
KnightmareCS
Anyone have a pic to show ground clearance?
Quick Reply: Anybody use a Fumoto valve ...
