SHIFT INDICATOR not working?
Old Mar 18, 2015 | 08:44 PM
cruiser1's Avatar
cruiser1
Default SHIFT INDICATOR not working?
Just what the title shows Shift indicator not working. Had trouble with the shifter not coming out of park. Fixed it by wiring lever back. After putting it all back together realized the shift indicator is not moving?
Any ideas or pictures on how to fix it?
Thanks in advance for any help.
Old Mar 18, 2015 | 11:37 PM
4SUMERZ's Avatar
4SUMERZ
The problem is that the indicator is not connected to the shifter shaft coupling.
It's an easy fix, but you have to remove the console, then get the shifter boot out of the way.
Then you can carefully loosen the silver part that normally covers the locking (pawl) tab. (pulls straight up and out)Once this is loosened, you can re-install the red indicator in the round slot on shifter shaft coupling, then re-install the silver part, drop down the shifter boot, and re-install the shifter number cap.
re-install the console and your good to go.
Here is a close up pic
Old Mar 19, 2015 | 09:31 AM
cruiser1's Avatar
cruiser1
Thanks LV2TOUR, I will try that today.
Old Mar 19, 2015 | 09:56 AM
4SUMERZ's Avatar
4SUMERZ
Good Luck. Let us know when you have it fixed.
Old Mar 19, 2015 | 06:05 PM
cruiser1's Avatar
cruiser1
[QUOTE=LV2TOUR;1589217969]Good Luck. Let us know when you have it fixed.
[/QUOT
THANKS LV2TOUR, it's fixed. Wasn't bad since I had it a part last week end. Must have slid out of it's slot when I had it apart. Just had to get the boot, plastic cover off was something extra I had to do.
Took a little under an hour to take apart and a little less to put it back together. Being very careful not to crack or break anything.
One happy camper!
Thanks AGAIN
Old Mar 19, 2015 | 06:34 PM
4SUMERZ's Avatar
4SUMERZ
One happy camper!
Thanks AGAIN
Glad you got it fixed and as good as new again
Old Mar 19, 2015 | 11:02 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Excellent pic and detail.
Thanks for posting.
Old Mar 20, 2015 | 10:20 AM
cruiser1's Avatar
cruiser1
Thanks for posting.
The locking tab shown in the picture is what I drill a very small hole in and put a wire in and tied back so the car will always come out of park. It always stuck in park at the worst possible moments. Not no more!
To SHIFT INDICATOR not working?
