Engine RPMs jumping
Old Apr 3, 2015 | 12:22 AM
JJB82's Avatar
JJB82
Default Engine RPMs jumping
I have an 09 base vette. Sometimes when I use the paddle shifters the RPMs will jump under rapid acceleration. Usually in the lower gears. I tried switching the traction control on and off, but that had no effect. Is anyone familiar with this condition?
Old Apr 3, 2015 | 01:33 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Does it feel like the trans is slipping or are you spinning your wheels?
Typically the A6 won't upshift when using the paddles if the wheels are spinning/losing traction and the revs will continue to rise until you hit the rev limiter.
Old Apr 3, 2015 | 08:46 AM
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
St. Jude 15 Year Donor
St. Jude Donor '08 thru '26
Welcome to the world of shift flare. A good A6 tuner can tune most if not all the flare out. I went through the same thing when mine was stock.
Old Apr 3, 2015 | 10:26 AM
JJB82's Avatar
JJB82
Feels more like the tires slipping
Old Apr 3, 2015 | 10:45 AM
JJB82's Avatar
JJB82
What is shift flare?
Old Apr 3, 2015 | 09:24 PM
Knob Jockey
If the tires are spinning then it's 'normal'.
The summer tires on the Vette do not perform very well in cold weather and this combined with them being old or maybe worn, could be contributing to your over-revving issue.
Old Apr 3, 2015 | 09:45 PM
JJB82's Avatar
JJB82
I'm assuming my tires are slipping, but I could be wrong. Any ideas as to what else it could be? I'm debating whether or not I should take it to Chevy to have it looked at
Old Apr 4, 2015 | 09:05 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If the tires are slipping, I'd expect to see a surge in the speedometer at the same time as the surge in rpm. At least, most RWD cars work that way.
To Engine RPMs jumping
