help needed with unknown wires .. please
Old Apr 4, 2015 | 03:05 PM
jusmillz's Avatar
jusmillz
Default help needed with unknown wires .. please
So in the process of changing my skid plate I notice 2 wires just hanging out freely. Need help with determining what are they for and where they go. They are on the passenger side neat the horn. one are yellow and the other is green with black.
Old Apr 4, 2015 | 08:23 PM
ICU2TV's Avatar
ICU2TV
I have two wires like that one yellow and one green with a black strip in it that goes to a sensor by the radiator. Sorry I am not much more help.
Old Apr 4, 2015 | 08:42 PM
EVRose's Avatar
EVRose
I'll guess its for the under hood light if you had one. I think I read when GM deleted the light they left the wires.
Old Apr 4, 2015 | 09:13 PM
CFB's Avatar
CFB
The service manual for my 2006 show these wires connect to the Ambient Air Temperature Sensor that is located on the RH Lower Radiator Support.
Old Apr 4, 2015 | 09:24 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
what he said. I have them also and was going to hook up the light but changed my mind after reading about a lot of issues causing the Battery to die.
Old Apr 4, 2015 | 09:48 PM
CFB's Avatar
CFB
On a 2006 the under hood light wires are OR and BK.
Old Apr 5, 2015 | 07:55 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Outside air temperature sensor.
Old Apr 5, 2015 | 10:40 AM
ICU2TV's Avatar
ICU2TV
I took two photos of these wire on my 2009 so you can make them out at the censor.
This is from the top down at the passenger side to the left of the horn attached to the radiator.
From the top down hooked to a censor on the radiator.
At the censor unit
Old Apr 5, 2015 | 12:03 PM
cclive's Avatar
cclive
Did you cut off the connector or was it already that way?
Wire colors can change from year to year, so it would be good to have some info on your car. Someone who has the service manual for that year can then look it up on a wiring diagram and tell you for sure.
Old Apr 5, 2015 | 08:09 PM
vetteright's Avatar
vetteright
Is your climate control system operating properly? I have heard of cases wherein the ambient air temperature sensor was inoperative that the A/C/Heater/Defroster does not work right.
To help needed with unknown wires .. please
