Well I'm thinking with 55K miles and squealing brakes it's time for a change. I want to get the brakes up to par with the power levels I'm pushing now (640rwhp).
Car is base model with base wheels and I'm not looking to go $3,000+ so no big brake kits due to cost and fitment. I'm on factory base model brakes with ZR1+ power levels so I figure it's time to balance the car out.
I'm thinking StopTech rotors but I'm a bit torn on what pads to throw on the car? I'm also open to suggestions on rotor options. I want slotted (not drilled).
As for the brakes, I don't like brakes that squeal like hell. I'm on Hawk performance ceramic pads and I'm not enjoying the squeal-fest I have at the moment. If I brake hard a few times they'll shut up for a short bit but then under light braking the constantly squeal. Thoughts? I'm looking to keep costs under $1,000 for total job and I'll likely be doing the labor myself.
I'm not road coursing the car so from what I've read I really don't need a bigger caliper or a full brake kit. I just want a car that can stop well from speed consistently. I was planning on powder coating the factory calipers. I'm looking to get the car to look a bit nicer in the brakes department too.
I did not have as much HP, but I used the stock calipers on my base and found a nice set of powder coated Z51 caliper brackets and got a set of Z51 DBA 2 piece rotors (since my disks were scored) from Ken @ KNS Brakes. I also used Akebono pads as I hated the squeal of other pads. No dust and no squeal. Much improved setup over base.
Better setup than stock base but without going with new wheels it is just about the best you can do. But I am not certain you will like this setup with your nice HP levels. If you want to go fast and track the car, you will have to pay to play and go with wheels and then you can get any setup you desire.
I would think the stoptech brakes for the Corvette are good. I had them on a 350z and they rocked. Stainless brake lines and Motul or ENI brake fluid is a good combination. I just recently flushed my brake lines with ENI fluid which is a dot 4 high temp.
How about upgrading to Z51 brakes. You get larger drilled rotors and new caliper brackets and you use the same calipers. The kit is only about $700.
Z51 rotors crack (and the fate of most drilled rotors which is why I'm against them). I was thinking of keeping stock calipers and powder coating them. I was thinking new rotors and pads and call it a day. No?
Check out the Carbotech 1521. I would use these with the Stoptech rotors. If you would like to order a set of 1521's let me know or just call me at 216-780-8825.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
