Orange Electronics TPMS
Old Apr 10, 2015 | 05:24 PM
lovinmyls1's Avatar
lovinmyls1
Default Orange Electronics TPMS
Just got back from Discount tire where I had installed new Firestone wide oval RFT's and new Orange tpms's .Well discount said they don't work so they put the old ones back in.The part number for a 2005 is correct-so anyone had this problem before ?
Old Apr 10, 2015 | 06:01 PM
EVRose's Avatar
EVRose
What does "don't work" mean though? They couldn't program them to the car? I had mine replaced at DT too and they had trouble with one of them. They had to break the bead on the tire and put to tool almost right against the sensor before it would program.
Old Apr 10, 2015 | 06:16 PM
Dano523's Avatar
Dano523
Buy the Ac Delco OEM's from amazon, and have them installed when needed (when the old ones dies).
The aftermarket TPMS sensors last around half as long before the batteries in them wear out.
Amazon.com: ACDelco 25758220 GM Original Equipment Tire Pressure Sensor with Valve Kit: Automotive Amazon.com: ACDelco 25758220 GM Original Equipment Tire Pressure Sensor with Valve Kit: Automotive
Old Apr 10, 2015 | 06:27 PM
daveholl's Avatar
daveholl
Discount Tire put 4 new TPMS in my 2005. They were gray in color and cost $60 each. They said programming was very easy. They said some corvettes require the use of a magnet to program.
Dave
Old Apr 10, 2015 | 06:50 PM
lovinmyls1's Avatar
lovinmyls1
They said they won't register? If that means program so be it. I asked them repeatedly if they have the tool to use to make them work and they said yes (I guess they would have to as they also sell their own brand).
The did put my old ones back in which are still working but are 10 yrs old.
Old Apr 10, 2015 | 08:30 PM
One Kick's Avatar
One Kick
Just brougt my 4 wheels and 4 new Delco sensors that I bought on Amazon to the local tire guy, he put the new sensors in and rebalanced the tires and charged me $100.00.
I put them on the car and had them programmed to the computer in 10 minutes.
Total cost including sensors $340.00. I think that's a pretty good deal.
Old Apr 10, 2015 | 10:20 PM
lovinmyls1's Avatar
lovinmyls1
I got the recommendation for these Orange ones from several members of this site. I will look into this more next week.
Old Apr 11, 2015 | 02:45 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
The Orange TPMS sensors work great!
Are you sure you bought the correct ones ... They changed somewhere around 2009-2010 from one P/N to another.
Old Apr 11, 2015 | 05:45 AM
lovinmyls1's Avatar
lovinmyls1
picked the part # off of a link to Orange's website-also verified it from some members here-thought I would try and call Orange Monday just to double check it.
Old Apr 11, 2015 | 11:06 AM
HOXXOH's Avatar
HOXXOH
What exactly is the part number on the part and what part number did you order, and from whom?
The reason I ask, other than Turbo6TA's comment, is that an order through Amazon or Ebay has been known to be processed by a third party who had stock that was mis-marked.
I've also heard, but not confirmed, that the USA distributor has closed their doors. Possibly due to the lack of good quality control by the manufacturer. I suspect Titan is importing their sensors from the same manufacturer, but recognized the QC problem and may be doing their own in-house QC. Without checking deeper into corporate info, it's also possible that Titan was created to transition into the replacement for Orange, since the product line is nearly identical and they're the only sensors I know of that are clonable.
BTW, the guy at Discount should have be able to determine the battery level, the ID code, and the communicating frequency. 2005-2009 Vettes are 315 Mhz.
Old Apr 11, 2015 | 02:53 PM
Dano523's Avatar
Dano523
https://www.corvetteforum.com/forums...ange-tpms.html
Old Apr 11, 2015 | 02:59 PM
Turbo6TA's Avatar
Turbo6TA
Not everyone has had problems with the 'Orange' TPMS sensors.
Mine have worked flawlessly since they were installed July, 2011 ... and continue to work fine.
Old Apr 11, 2015 | 03:42 PM
Dano523's Avatar
Dano523
Op just stated that is OEM are 11years old (car built in 04, sold in 05), and still working fine.
Do you really think that your going to get that many years out of an after market TPMS, and when you can get OEM for the same price as an after market unit that has to be cloned to first work?
Old Apr 12, 2015 | 02:48 AM
HOXXOH's Avatar
HOXXOH
Just to bring you up to speed on these aftermarket sensors.
OEM sensors cost 20-40% more than aftermarket, depending on the source. The aftermarket Orange Electronics/Titan can be cloned, but it's not necessary. The OEM sensors cannot be cloned. The service life on all sensors is related to the functions and times of access, not a calendar.
Don't restrict yourself to thinking about just the 4 wheels currently on the car. By cloning, wheels used for summer, winter, snow or racing, etc can be swapped back and forth without the need for reprogramming.
To Orange Electronics TPMS
