When should fluids be changed
Old Apr 12, 2015 | 04:40 PM
Coyvett's Avatar
Coyvett
Default When should fluids be changed
When should I change the brake fluid, clutch fluid and coolant on a 2012
GS manual? Car has 4,000 miles.
Old Apr 12, 2015 | 06:06 PM
1968swbbigblock's Avatar
1968swbbigblock
Clutch fluid now
Brake fluid depends upon how hard you drive the car and the humidity where you live - most can get by 5 years without any work.
Coolant - see you at year 5
Old Apr 12, 2015 | 06:22 PM
Coyvett's Avatar
Coyvett
Originally Posted by 1968swbbigblock
Clutch fluid now
i'm in Alabana, high humidity and do not drive it hard. Thanks
Old Apr 12, 2015 | 07:51 PM
truckplay's Avatar
truckplay
clutch fluid as soon as you buy it to get it clean, then once a year depending on how you drive it, just keep it clean. the brake fluid every 2 years unless you run dot 4 then every year. the coolant is up to you, I change mine every 3 years. oil every year.
To When should fluids be changed
