Anyone knowledgeable on weight transfer?
Old Apr 19, 2015 | 11:38 AM
Lew Shaw's Avatar
Lew Shaw
Default Anyone knowledgeable on weight transfer?
On my 2010 C6 GS Convertible, I recently added an Edelbrock E-Force which added 90 lbs to the front weight. I removed the front battery that weighs 35 lbs and added a larger battery in the trunk that weighs 50 lbs. I just assumed that the wight transfer was (+90, -35, -50) for a net of +5 lbs to the front. However, I'm told it's much more complicated than that, so can someone please educate me.
Thanks!
Lew Shaw
Old Apr 19, 2015 | 12:35 PM
bobeast's Avatar
bobeast
Thanks!
Lew Shaw
I think you've been a victim of pseudo-science. It really is not more complicated than that. You shifted front to back weight ratio by 5 lbs.
Old Apr 19, 2015 | 12:47 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
You have 90(front) - 35(front) + 50(back). You added 55 lbs to the front and added 50 lbs to the rear. Your car now weighs 105 lbs more overall, with 5 lbs more of that in the front, so it's balanced almost as before but the car is about 3% heavier.
What about the extra length of battery cable? Isn't that a lot heavier for the rear battery? I realize it's probably fairly evenly distributed front to back, but it'll make the car even heavier because of its added mass.
Old Apr 19, 2015 | 01:31 PM
LedZepper's Avatar
LedZepper
It may be a little more complicated, because you slightly changed the center of gravity and the moments of inertia about it. But the effect is probably negligible. Such things happen with carrying passengers, adding fuel, or putting a case of beer in the trunk.
Anyway, the only real difference you'll notice is the Edelbrock. Have fun!
Old Apr 19, 2015 | 01:55 PM
Lew Shaw's Avatar
Lew Shaw
That's what I thought. Thanks for the confirmation!
Old Apr 19, 2015 | 01:58 PM
Lew Shaw's Avatar
Lew Shaw
Again, thanks for the confirmation. The cable is heavier than you realize since I used 1 gauge and not the 4 gauge used in a ZO6.
Old Apr 19, 2015 | 02:03 PM
Lew Shaw's Avatar
Lew Shaw
Originally Posted by B Stead
It's best to keep the mass of the car between the front and rear axle lines. Putting weight near the bumpers makes a more leveraged lateral swing-out force.
I wouldn't go to a heavier battery. And in fact if heated seats, high amp stereo, and high beam headlights are avoided then the Braille 21 pound battery would be enough.
Well, if I were building a car for competition, I would do things much differently. My car is a boulevard cruiser and a nominal difference in total weight is somewhat insignificant to me, but I appreciate your comments.
Old Apr 19, 2015 | 02:05 PM
Lew Shaw's Avatar
Lew Shaw
Thanks!
To Anyone knowledgeable on weight transfer?
