Reverse Issue normal or not?
Ok, Mind you I have flushed the Trans fluid and rear diff and also currently going thro the ranger method. Fluid is still brownish.
When I go into Reverse "sometimes" its smooth but most of the time it takes some effort and when I do that I feel the shifter click 2-3 times and into gear. Mind you I'm applying some force or effort but to me doesn't seem normal unless it is I don't know. It doesn't just go in with one click and some push "sometimes" it does , majority of the time I have to give me some more effort and I feel the shift hit 2-3 clicks and its in gear or just 2 clicks. Also what did happened a few times I would feel one "big bump " and not really a click, mind you with some force little more then usual.
Dano523 said this is normal but I want to hear everyone else on this topic. I brought the car to the dealer and they said nothing is wrong with the car. The service manager drove it and the mechanic. So its normal to kind of force the car into reverse or give it some effort to go in? My thing is the clicks to get into gear besides the effort part
All the other gears are fine I can literally use no effort at all to shift which I think is normal or a tiny bit of effort not a lot of effort. I hope I'm explaining it good enough and the effort part. I'm really not sure what's a normal amount of effort for this to actually be normal.
The gear doesn't not grind just simply doesn't go in or I have to give some effort to get into gear "Reverse" First I heard is normal I guess. some part of just doesn't see having to use effort in a car to get into gear Idunno. Thanks guys.
Sorry, its a 05 with 25K 6speed.
My 2006 at times will not go into any gear at random, but finding another gear that it will go into and letting the clutch out slightly to move the car a bit, helps get it into the gear I wanted to use, including reverse.
My thought is that the synros/gear will just get hung up in a non alignment position, and moving the car slightly, changes that.
A manual will always seem to shift much easier when in motion, aiding in the gear mesh process.
After he would get into reverse he would go into another gear then put in neutral push the clutch down and go into reverse again to see what happens.
After I get it into gear if I back out and go in its smooth as butter. I also notice today when I get it onto reverse back out and go into 1st let's say, when I go back into reverse its fine BUT if I go into first and move about a foot when I goto reverse its give me alitle trouble
