Overheating?
I have had a coolant level warning come up before and I've brought it to the dealer. They couldn't find anything wrong and topped off the fluid. Then its fine for a month or so then shows up again.
Is this car that sensitive to the coolant level?
I made a wand out of 3/8 soft copper, end crimped with 2 small holes drilled in it. Do a search there is a good thread about how to make one.
Need to do mine again before the summer heat.
I'll look at blockage first but my thought is its a sensor as has been suggested because it really doesn't run hot and only shows up during short bursts of acceleration where you have to slow down quickly or short bursts of high revs in traffic. So where the temp rises quickly but doesn't necessarily get hot.
If that is true above, something IS going on. A quarter inch from the top of the tank means (to me) there is too much fluid in the overflow tank. It shouldn't be that high ever, hot or cold. The normal cold (early morning before you start car) is supposed to be somewhere betw. the hot and cold line on the outside of the tank, usually around midpoint.
Again, if the level hot is what you say, for whatever reason, the water pump is pushing fluid out of the engine and into the overflow--and it is not returning to the engine to cool---which means to me that the engine may actually be running low on fluid (slightly, but maybe enough to trigger a warning). To me, this could be several things but the only things I can think of are water pump or thermostat---or some sort of clog or lack of power fr. the pump.
You don't state year of car, miles, or last time rad fluid was changed, so it's difficult to comment on it from that standpoint. More info would help. Also, any mods to the engine of any kind incld. a tune, headers, etc.? Finally, when the engine temp starts to rise, does the FAN come on?
You don't state year of car, miles, or last time rad fluid was changed, so it's difficult to comment on it from that standpoint. More info would help. Also, any mods to the engine of any kind incld. a tune, headers, etc.? Finally, when the engine temp starts to rise, do the fans come on, both of them?
Oh, and BTW, there's only one fan.
But when fully warmed up, the level is fairly close to the top of the tank.
Being on the front of the tank, the indication is effected by any nose up or down incline.
They did the Catalytic converter swap at the same time. So she's up to date.
Thanks for all your feedback guys.
One fan, OP.
