check your cabin filter!
Cruising
New to me GS Convertible. 41K miles. This has to be the original cabin filter? (old on the left, new on the right).
What else should I be checking?
That's 1 of the 27 things the dealership service department checks for me when they change the oil and filter on my C6.
That filter doesn't get get dirty very fast around here.
I've got a dry sump GS, I thought I read somewhere that the cabin filter was really hard to access, is that true? Any links or pics on how to get at that filter??
Thanks!
Thanks!
Cruising
Battery's in the trunk in the dry sump, huh? I can't imagine the HVAC boxes are different. I'm sure someone here's got a good method. Surely will coincide with an oil change!
I keep 3-4 in stock at any given time and pop a new one in each spring when my 2009 comes out of hibernation after a long winters nap. Some years it's full of crud (straw & hay), just depends on where I've been the previous 12 months.
About twice a year I make a point of running mine up on the ramps and inspecting the front of the radiator after I found a plastic shopping bag plastered to the radiator. Reason I looked was the car was running a little warmer then normal.
I think of Corvettes as bottom feeders. They ride low and source their air near the roads surface where all sorts of debris lurks. Anytime I run over paper, plastic bags etc. I always watch for it to emerge and not come along for a ride. Also picked up a shopping bag in the front suspension when I pulled over after one appeared behind the car ahead of me and then disappeared.
As for the cabin air filters, they are cheap and easy to inspect and change as necessary.
-G
-G
Received 4,520 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I replace mine every other year.
Just flip up the 3 clips you see in the photo, slide out the old filter, slide in the new, then secure the cover again with those 3 clips.
I use this filter, available from Amazon for about $15.00...
On the dry sump system, the lines are in the way, so it's a little tricky working around them, but still a very easy job, just a few minutes.
Mine looked like that as well. I was reading the manual after bringing mine home and didn't know it had a cabin filter. Went out to the garage and found out the original didn't not know either.
snip
snip
snip
snip
