Bent Wheel
Just had my first wheel alignment and balancing checked by a Firestone dealer I trust. Dealer reported that my left rear wheel is slightly bent. Saw this by wobble on balance check. Dlr said this is slight, shouldn't affect handling, but may affect tie wear. Michelin tires with 8K on them don't show unusual wear.
Chrome Wheels are pristine, with no apparent damage. I've been to 145mph and no felt vibrations.
I'm past factory warranty. Does anyone know if there is an issue with 2012 chrome wheels? Any factory recalls? I searched for bent wheel, and didn't find anything.
I may ignore this, as it doesn't seem to have any noticeable effect. Any thoughts on this?
Recalls, not that I recall reading about (no pun). Anyone can easily bend a wheel touching a curb just so, going over railroad tracks, hitting a bump in the right (wrong) way, etc.
P.S, Find is strange that the tire shop did not sugest that the rim be straightened, since most of them have a repair shop that straighten rims for them (most are mobile services that will come to the shop to straight the rim there).
It's easy to say they are just trying to sell more wheels, or it's easy to say that aluminum is more prone to cracking and so you really should replace instead of straightening.
I've got stock painted wheels, so replacements in good condition are cheap. Chrome, not so easy or cheap.
If the previous check passes, then check the wheel off the car for lateral runout. The spec is .030" You can also check the tire off the car for lateral runout The spec is .050"
If you don't have a dial indicator, you can still do a rough check by mounting your rear wheel on the front spindle and with the tire off the ground, place a block of something fairly heavy next to the tire near the tread (as above) and rotate the tire. The tire should push the block away if it's not 100% true. Then find the spot on rotation where the tire touches the block and rotate the wheel 180 degrees. If you can drop a penny between the tire and the block at that point, it's at least out of spec and should be more thoroughly checked with a dial indicator. If a dime easily falls through, it's more likely the problem was dirt on the wheel mounting surface or a slight mis-fit on the balancer when the wobble was first noticed.
If you can't feel it and the tire expert in your area said leave it alone....leave it alone.
Buying new rims for a little run out that's within gm guideline tolerance I think your setting your self up for ongoing ridiculous expenses..
If the runout was beyond gm guidelines then yes I would buy new wheels...
Within guidelines ....just enjoy your car as is....
No vibration at all? Leave it alone.
I tend to buy practically new preowned take off rims every time or every other time I buy tires...the roads around my neck of the woods do eventually take the wheels beyond gm tolerance levels...
Chrome rims are not on my list for just this reason....they look good but can not as easily be repaired in my opinion.
Leave well enough alone...jmo
I don't have the equipment to remove a wheel w/o risk. (I do change my fluids, though, on friend's drive-on lift - that and cleaning is the extent of my mechanic work on this car)
The Balancing shop (local Firestone) had the wheel off the car, and checked for dirt; also said it's the wheel, not the tire (Michelins). Unfortunately, I wasn't available to see for myself.
The tire has about 8K miles, and didn't show abnormal wear, which leads me to suspect don't fix it may be the way to go.
I've talked with the recommended wheel shop, who will check both the wheel and tire (separately, off the car) and make a recommendation. Wheel shop said if wheel can't be straightened, or after attempted straighten, isn't in spec, there's no charge.
I'm not trying to be **** about this. I occasionally drive brief bursts over 100, but I want some piece of mind. And, I don't want to replace the wheel, unless absolutely necessary.
I'll report back on what I learn - maybe this experience will help someone else.
Discount tire rebalanced all 4 after installing new TPMS. They said the bent rim did balance out but the runout was significant. No vibration up to 70mph, but it still bothered me.
So, I met repair guys at Mercedes dealer (they travel around and try to do several wheels at a time for dealers) and in 45 minutes they had the wheel back on .........runout was .020 after repair. Clever how they did it.
Dave
