EGR Valve LS2
Old May 19, 2015 | 06:30 PM
Roadstarblue's Avatar
Roadstarblue
Default EGR Valve LS2
LS2 have a Egr valve ?
Old May 19, 2015 | 06:41 PM
slayer6x6's Avatar
slayer6x6
Negative sir, I believe the LS engine stopped using an EGR around the year 2000.
Old May 19, 2015 | 08:10 PM
Roadstarblue
Thank you just trying narrow my issue down. it is putting out EGR codes.
Thanks so much,
Old May 19, 2015 | 08:19 PM
VET4LES's Avatar
VET4LES
It still recycles the fumes but without the valve.
Old May 19, 2015 | 09:14 PM
Roadstarblue
So do you think it could be 02 sensors ?
Old May 19, 2015 | 09:23 PM
87SAM's Avatar
87SAM
What are the codes?
Old May 19, 2015 | 09:43 PM
Roadstarblue
Originally Posted by 87SAM
What are the codes?
P0402 and P0403
Old May 19, 2015 | 10:03 PM
87SAM's Avatar
87SAM
Originally Posted by Roadstarblue
P0402 and P0403
Yes, I have since read your other thread. I still think you have your numbers mixed up as they should be P0420 & 430.
You stated you installed a Corsa exhaust (took that as just mufflers). That in itself would not cause those codes, unless you somehow you ripped out your rear O2 sensor wires while doing so.
At the same time did you also do any work on the air intake side of the engine?
Below is link to the C6 codes:
http://www.digitalcorvettes.com/foru...ad.php?t=99435
Old May 19, 2015 | 10:15 PM
Roadstarblue
http://www.digitalcorvettes.com/foru...br /> t=99435
The codes came on after I rode the Dragon I cleared the codes and just yesterday I installed a vararam intake and the code came back same #s.
After we drove the dragon I cleared the codes and about 1 hundred miles from home the light came back on same code.
Old May 19, 2015 | 10:22 PM
Roadstarblue
looking at the link you put up it is the same thing my scanner said bank 1 an 2 any thoughts ?
Old May 19, 2015 | 10:29 PM
87SAM's Avatar
87SAM
I'm sorry but, I'm having a hard time following you between this thread and you other thread.
1) confirm what codes you have, rescan if needed
2) had you preformed any exhaust/intake/anything work before these codes came up
Old May 19, 2015 | 10:32 PM
Roadstarblue
I will lift it Tomorrow and check the 02s and check the temperature from front to back of the cats to see if it is the 02s
Old May 19, 2015 | 10:34 PM
Roadstarblue
No just over axel corsa mufflers,
Old May 19, 2015 | 10:37 PM
Roadstarblue
I cleared the codes so will have to wait until light comes back on
To EGR Valve LS2
