raining
Maybe you have medians in all the streets, really good drainage, or very courteous drivers that don't create waves where you live. However, in the Phoenix area a 1/2" of rain can temporarily flood some streets up to 3-4" deep in less than an hour. Then the guys with lifted pickups just love to splash as much water as possible, which can create waves 6-8" high. It only takes one wave to hit that open inlet to kill your engine and the only defense is to either block it or shut off the engine before the wave hits.
Well that's not pompous at ALL.
I daily my C6. I have 2 other vehicles that I could use as a DD. Every once in a while I will drive something else, but I just enjoy driving the corvette too much.
To the OP, I live in central Texas, and we got over 5" of rain just last night alone! This is one crazy season so far. Just don't go through any large puddles and you should be fine.
The air inlet doesn't have to be submerged to get water in the cylinders. A single wave that splashes a quart or so, directly in the inlet can be enough to hydro-lock and kill the engine.
Think of it as hanging your head out the window with your mouth open. Rain is not enough to make you choke, but if an oncoming car splashes through a puddle that hits your face, you'll have more water in your mouth than you can handle all at once, yet you weren't submerged.
I also use a paper filter in my Vararam for better filtration. It's a lot harder for water to get through the paper, than the original mesh filter. If you doubt that, watch how water flows through the mesh filter unimpeded the next time you wash it. Then do the same with a paper filter. You might even recognize that dirt can flow through the mesh filter almost as easily.
You'll need to slightly trim/sand off about 1/8" of the rubber seal on each end. The paper filters trap a whole lot more dirt.
Amsoil - EAA240
Purolater - A25596
Fram - CA10085
NAPA - 9186
WIX - 49186
STP - SA10085
Carquest - 83186
These are replacements for VW 2.4 L from about 2006-2012.
According to the numbers, it looks like Carquest, NAPA, and WIX are identical and Fram & STP are also twins, so you might as well shop by price.
