Eagls Eye LED Tail lights
Old Jun 7, 2015 | 04:24 PM
vettenut's Avatar
vettenut
KY Events Coordinator
Default Eagls Eye LED Tail lights
I just got four and two have red tape on the package and a number 2.
The other two have green tape and a number 1. Is there any difference?
Old Jun 7, 2015 | 04:32 PM
boraxman's Avatar
boraxman
Yes difference also I believe theres something stamped in the plastic to tell if its an inner or an outer/
I would also add some extra sealing, if they get moisture in em there done.
Old Jun 7, 2015 | 04:43 PM
vettenut's Avatar
vettenut
What I found was two marked R (Right)? and two marked L (Left)?
Old Jun 7, 2015 | 04:47 PM
boraxman's Avatar
boraxman
Its been a while, someone else will chime in....
Old Jun 7, 2015 | 05:03 PM
kedar's Avatar
kedar
St. Jude Donor '12
There is no difference between inner and outer. Only difference is driver's and passenger's side.
Old Jun 7, 2015 | 05:16 PM
HK770's Avatar
HK770
Left /right...... so that the wiring and plug retain same direction and Don't cause a problem.
IMHO
luck
Old Jun 7, 2015 | 05:18 PM
Filiatrault9's Avatar
Filiatrault9
LL for left side lights, RR for right side. No inner or outer. Enjoy the new look!
Old Jun 10, 2015 | 07:13 AM
SCcues's Avatar
SCcues
Pro<br><img src="/forums/images/ranks/500-1000.gif" border="0">
Default Eagle Eye Lights
It's been a while since I installed them on my car, but I've been very pleased with the look of these lights on the car. They are bright and anything that helps your car stand out in traffic is a good thing with so many people texting and talking on cell phones. I worry every time someone pulls right up to the back of my car that they may run into the back of it. With the Eagle Eye lights they sure can't say they didn't see you! I like these lights a lot on my car.
Old Jun 11, 2015 | 09:53 PM
Lew Shaw's Avatar
Lew Shaw
The ones I bought were also labeled 1 and 2. If you look at the lenses closely, you will see that the spokes in them are positioned differently. I called them and was told to mount the 1's on the outside and the 2's between them. I did and they matched (from left to right L1-L2-R2-R1). YMMV!
Lew Shaw
To Eagls Eye LED Tail lights
