Spark plug wires
The car is an 06 has LG long tubes and a vortech T-trim. What plug wires are you guys using? Where are you getting them? I'd like to order tomorrow and have them within the two weeks.
The MSD sounds good, you guys with headers, did you order the straight or singled versions and did you get the insulator socks? Thanks.
Hmmmm. A miss should really set a code.
I tried to make it code but it won't flash for me. I hope it's a wire(s) and not coil.
Engine dead cold!!!!!
Pull the fuel rail covers,
Pull the spark plugs
Pull the spark plug wires.
Unhook the spark plug wires coil connectors.
Start with the plugs, hence clean them and check the gaps (should be .040). Now install them, and it up to you if you want to use anti-seize grease on the plug threads or not. The spark plugs get torqued to 11ftlbs only, and again, do not pull or install the spark plugs unless the motor is dead cold to room temp!!!
On the plug wires, and the coil sockets and connectors, break out some spray electrical contact cleaner, and clean all the connectors. Also, take a multi meter to them to check resitance across the wires.
Now a dab of dielectric grease on the coil connectors, on the plug connects both ends, and inside the the plug boots, then reinstall all the connectors. The coil connectors are straight forward, but on the spark plug wires, make sure that you feel and hear the connectors click in place as you are installing the boot ends in place.
Now with the spray contact cleaner still in hand, pull the MAF and clean it as well. Only use a dab of dielectric grease on the wire connector to the socket, and leave the inside parts of the MAF bone dry.
Also to point out here, the stumble/mis-fire could be coming from an after market air filter system!!!! All the after market companies love to go on and on about how they system will outflow the stock air filter (which the stock filter system is already out flowing the motor already), but what is missing, the after market system has to do that without creating disturbances to the air flow across the MAF a well!!!
So if the problem is a MAF one, let just hope that it a over lubed air filter that has fouled the MAF sensor only (what cleaning it will resolve).
P.S, if the car has been turned, then the tune may need to be checked as well. Forget DIC fault codes, and just pull a data log on the car to look at the knock sensor read outs instead. With the temps getting hotter, and E-10 now common place, could be a problem with either spark advance, or injector lean out problems for mid throttle caused by the E-10 in hotter weathers.
Lesson learned is check plug wire resistance and do not let appearance determine serviceability. The dealer was Landers Chevrolet in Huntsville Al.
Good advice.
