maintenance 2011 GS
Old Jun 11, 2015 | 07:42 PM
dkimura2011GS's Avatar
dkimura2011GS
6th Gear
Default maintenance 2011 GS
Hello, Do you have instructions on how to replace the air filter on a 2011 Grand Sport? I just purchased a K&N drop in air filter & would like to install it. Is it fairly simple? Also, I have a engine check light that comes on & off, did a OBD, scan states P0330, knock sensor 2, bank 2. Where is the located, is it nearby the oil filter & is it easy to replace. Please advise AC Delco part number if available. Thanks in advance!
Old Jun 11, 2015 | 08:45 PM
JakeC6Racing's Avatar
JakeC6Racing
The knock sensor I can't help with, but this should help you with the air filter https://www.corvetteforum.com/forums...with-pics.html
