Invisicord
Old Jun 13, 2015 | 07:38 PM
vettenut's Avatar
vettenut
KY Events Coordinator
Default Invisicord
Anyone using a Valentine 1 in a C6 able to tell me where to insert the hot wire (red insulation) ground wire (green insulation)? also the Invisicord ends are flat. Do they insert with the flat up or sideways?
Old Jun 13, 2015 | 09:45 PM
George's_Vette's Avatar
George's_Vette
This forum post should sort things out for you and I think there are video links for visual help.
https://www.corvetteforum.com/forums...nvisicord.html
The hardest part I found was getting the multi wire plug out of the back of the mirror to insert the two new wires to the + and - source feeds to the mirror.
George
Old Jun 13, 2015 | 09:50 PM
Walkthedog's Avatar
Walkthedog
Default Invisicord
I just put my V1 into my car yesterday. So I am very familiar with this.
I searched the Forum for "Installation Invisicord" knowing I used Forum member Bugman instructions a few years ago. They are still there complete with photos. You put the ground in the upper left corner and the hot in the fourth slot that has a pink wire there. The pins flat vs edge don't matter and I never paid attention to it. The whole process takes two minutes. I hope this helps
Old Jun 14, 2015 | 03:45 PM
Don-Vette's Avatar
Don-Vette
This is how I plugged my 9500ix with the cord. Btw: I pushed the flat pins in ABOVE existing wire to get power pushing them in below the wire did not make a connection for me. Also hold the mirror in one hand while pulling plug out wiggling it side to side while doing so. You don't what the mirror to pull off!
To Invisicord
