How do you exit your C6?
In my C4 and C5, there were either floor sill pads or bumps in the door jamb to place your outboard hand and hold/push yourself up and out. The only such area I think I've found on my C6 is a raised area just above the door latch on the rear door jamb. Is this it? If yes, it's not nearly as convenient and easy to use as past models...to me anyway.
What say you?
Thanks in advance, Coolarrow in Houston
What say you?
I had a 1993 mazda rx7 FD3S which is TINY, like a miata on steriods so i was used to getting in and out of a tight car.
Mind you i am a small guy. 5'9 160lbs so i don't need much help, just a little momentum getting out of these small low cars.
I try not to lean on the side bolster too much cause i don't want premature wear (car has 7k miles) so what i do is i put my left leg out and i push onto the door sill to get myself out while holding the steering wheel with my right hand for extra stability.
Car is a weekend car so i try my best not to abuse it. I know its a car and its meant to be driven and treated like an actual car but i'm used to taking really extra care, almost like OCD lol. Been that way with all my toys since i first got into cars.
Cruise-In II Veteran
Cruise-In III Veteran
Absolutely have to agree that is the best method. A buddy of mine taught me the trick long ago and I still believe it is the best method on any low slung vehicle.
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
I just turn and pivot completely to the side and then get out, I think the trick is turning completely to the side. I have to admit it's a challenge at times. I also tilt my steering wheel all the way up before getting out. The older I get the more I struggle.
From: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
I just place my left foot out first using the strength in my left leg to stand. I use my left arm ever so slightly just for balance on the top of the seat. I sometimes use my right arm on the a-pillar too. I always avoid the left lower side bolster at all times entering and exiting so the bolster doesn't get flattened down and wrinkled.
MT
MT
Upon stopping and turning off engine I free fall onto the pavement, pick myself up and wipe my clothes clean. Started wearing knee pads when I turned 60 which helps quite a bit.
I was watching an episode of Magnum P.I. recently and Tom Selleck (a large man) exits his tiny ferrari 308 this way, and he makes it look effortless...Like a pro!
The only caveat I'd note with this method is if the sill is wet from car washing or rain (the door is sealed but still can get some water here) I've had my palm just slide off and almost fallen on the ground. So watch out for that.
