Alternator Problem
Old Jun 16, 2015 | 08:13 PM
wjhgolf's Avatar
wjhgolf
Default Alternator Problem
My alternator is making a "chirping bird" noise that increases as I accelerate - idling or driving. I think I need a new alternator. Any other opinions are appreciated - I haven't had a shop check it out yet.
Old Jun 16, 2015 | 08:25 PM
EVRose's Avatar
EVRose
Look at your balancer at idle and see if its wobbling.
Old Jun 16, 2015 | 08:32 PM
wjhgolf's Avatar
wjhgolf
Where is the balancer - what does it look like? What about the noise I am hearing?
Old Jun 16, 2015 | 08:36 PM
wayback's Avatar
wayback
Do a search for harmonic balancer. There is a good video that shows a good one and a bad one.
Big pulley looking thing coming off the crank, front center of eng.
Old Jun 16, 2015 | 08:56 PM
EVRose's Avatar
EVRose
The noise you're hearing is common when the harmonic balancer starts to wobble. Agree, do a google search for C6 Corvette harmonic balancer.
Old Jun 17, 2015 | 12:11 PM
C6ToGo's Avatar
C6ToGo
It could be the alternator. I had a noise it that area that i couldn't pin down. Used a mechanics stethoscope to see if it was PS pump or alt.
Still couldn't tell and, of course while on an out of town trip, the alternator pulley started wobbling with noise getting louder. On my way to try to find a parts store, the front bearing finally completely failed to the point of knocking out the alternator output.
Old Jun 17, 2015 | 01:26 PM
wjhgolf's Avatar
wjhgolf
Default Maybe the A/C tensioner???
A dealer told me that only 1/20 customers who think their problem is the balancer turns out that way. They suggested that it is probably the A/C tensioner??? Much less costly to fix.
Old Jun 17, 2015 | 02:43 PM
zali0104's Avatar
zali0104
Dude....... Remove the accessory belt, place a long screwdriver against each accessory, works like a stethoscope. Now turn the pulleys , each bearing should not make any noise as you spin by hand.
Also check the belt for oil or antifreeze contamination. Thie can also caure squeeking/squeeling sounds.
Good luck.
Old Jun 17, 2015 | 05:23 PM
EVRose's Avatar
EVRose
I can't count the number of times I've read on here how a dealer first replaces the belt. Then the noise comes back and they replace it again. It comes back and they replace a tensioner. Still noise comes back and they finally solve it by replacing the balancer.
Old Jun 17, 2015 | 07:39 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Good luck.
Wow, old-school screwdriver to the ear trick.
Don't you know all us modern Vette guys have electronic probes to listen to our cars using our IPAD's??!!
Old Jun 17, 2015 | 08:27 PM
HBsurfer's Avatar
HBsurfer
I replaced my alternator when the bearing started to go out. Made a chirping sound. Removed the belt and spun all the pulleys with an auto stethoscope and singled out the alternator. It was still charging fine but I replaced it. Chirping is gone. Pretty sure it is not a big deal to replace that bearing but I just replaced the alternator. Took about 20 minutes. Good luck.
Old Jun 17, 2015 | 09:07 PM
Dano523's Avatar
Dano523
Hate to say it, but GM does tend to use bearing greased on the sparing side. It not only the alternator bearings, but the idler and tension pulley bearings for the belts as well.
As for the bearings, they are cleanable/re-greaseable if caught soon enough as they go dry; before they wear out instead.
As for the valeo alternator, a rebuild kit is around $45, which includes a new slip ring, brushes, and both front and back bearings.
For about $15 more, you can get the voltage regulator with the bushes pre-installed, instead of just a new pair of brushes to replace the worn one in your old voltage regulator.
As for it if just the bearing starting to squeak, no parts really needed,and it just the bearings that need to be pulled to be cleaned and re greased instead.
To Alternator Problem
