Can I use my C5 jacking pucks on my 2013 GS C6? Sold my C5 but kept these. A guy today tried to discouraged me from using them. Said C6 were not meant to be jacked in this fashion...Had my C5 up a bunch of times with them...
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
C5-C7 supposedly all use the same puck but I do know there MIGHT be a difference because of the thickness of the frame. Just try them.
Oh, and ignore whoever told you not to use pucks on a C6. They obviously know nothing about this car. You MIGHT be able to position the jack correctly every time and not do any damage but I had a dealer who found they couldn't and broke a rocker panel. As far as jacking is concerned, you can lift 2 wheels on one side at once with a single jack and not damage a C6.
Tks everyone, good to hear about the pucks. Thought I'd better ask about jacking the C6 up since I just purchased it and hadn't read up on it..thought that was a bit crazy..
While here let me ask, I lowered my C5 on stock bolts, can this same procedure be done on the C6???
