ambient ait temp
Old Jun 21, 2015 | 01:59 PM
NoRuls's Avatar
NoRuls
Default ambient ait temp
When I first start my base 06 the ambient air temp gauge reads 70 degrees+- regardless of the actual temp even if it's 90. After 10 minutes it slowly gets to the actual temp. Other cars I've owned show the actual temp at start. Is this normal? If the ambient sensor is the culprit it's a easy $10 fix, if it's a computer reset I won't bother. Any clues?
Old Jun 21, 2015 | 02:29 PM
ttx350z's Avatar
ttx350z
I believe there's a certain criteria before it updates automatically. Like over a certain speed.
You can reset it manually by pressing the windshield + rear window defrost + increase fan speed at the same time to update it.
Old Jun 21, 2015 | 04:02 PM
Vette_DD's Avatar
Vette_DD
It's designed that way on the C6. To get the current outdoor temp. immediately, press the following 3 buttons on the A/C control simultaneously (see attached diagram):
Fan Control
Air Delivery Mode Control
Rear Window Defogger
Old Jun 21, 2015 | 05:21 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I think the displayed temperature will go DOWN right away ... you may be leaving a relatively warm garage and going to a cold outdoor temperature.
But it won't go UP right away (a 10 minute delay as I recall) so it won't display a false reading from sitting in the sun, which if it did would cause the climate control to erroneously either not heat or start cooling when the actual outside temperature actually may require heat or no cooling.
Old Jun 21, 2015 | 11:53 PM
NoRuls's Avatar
NoRuls
Thanks' for the answers! I'll give it a try. Ron
Old Jun 22, 2015 | 12:23 AM
Vette_DD's Avatar
Vette_DD
2006 owner's manual, pages 3-28 and 3-29:
There is also a sensor located behind the front bumper.
This sensor reads the outside air temperature and
helps to maintain the temperature inside the vehicle.
Any cover on the front of the vehicle could give a false
reading in the temperature.
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 10 mph (16 km/h) for
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation.
There is also an inside temperature sensor located to the
left of the ignition switch. The automatic climate control
system uses this sensor to receive information, so if you
block or cover it, the system will not function properly.
To ambient ait temp
