Car will not start
Old Jun 21, 2015 | 09:42 PM
Pho Nguyen's Avatar
Pho Nguyen
7th Gear
Default Car will not start
I've got a 2006 c6 automatic. I've been having problems lately with starting my car. Thinking it was a dead battery the last few times I would put cables on my car and it would start. Well the other day it wouldn't. I went and bought a new battery still nothing. Dash would go dark when I press the start button. Give it about 15 seconds and the ash would flicker back on. I've disconnected the battery numerous times and that didn't work either. Need help diagnosing the problem
Old Jun 21, 2015 | 09:57 PM
09_BSM_Z51's Avatar
09_BSM_Z51
Internet diagnosis/guess is that the starter or starter solenoid went south. But to be sure you might want to have a pro take a look at it. If it were fuel, spark, or computer you'd get a check engine light. Your symptoms are similar to a few cars I've had where the starter gave out including my Fbody. Since GM likes to use the same failure routines on different cars my gut says starter.
Old Jun 22, 2015 | 12:29 AM
Pho Nguyen's Avatar
Pho Nguyen
7th Gear
Where is the starter solenoid located? I'm going to have my mechanic change the starter tomorrow. If that isn't the problem, what will it be then? It couldn't be my steering column lock could it? I've got an automatic. That doesn't happen on an auto does it?
Old Jun 22, 2015 | 12:38 AM
HBsurfer's Avatar
HBsurfer
While I have not replaced my starter on the C6 yet, pretty sure it is attached to the top of the starter.
Old Jun 22, 2015 | 04:46 AM
fred D's Avatar
fred D
Have you cleaned and tightened the battery cables? Top and at the starter. I had problems once with a loose connection on the starter end.
Old Jun 22, 2015 | 07:17 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Your symptoms are of a heavy load on the battery that it can't handle. The dash going dark for 15 seconds is normal during a start procedure where the engine fails to start. I have to assume the engine is not turning over?
#1 - Is the battery charged? Many "new" batteries have been sitting on the shelf for years and are dead. A bad battery should also be causing problems opening the doors.
#2. Are battery cables clean and tight at the battery? Bad connections at the battery will often be evidenced by the terminals getting hot.
#3. Hopefully disconnecting the battery multiple times has not destroyed the ECM or BCM computers. That's never a good idea because it does nothing to "reboot" anything. It just sends voltage surges through all the electronics.
The fact that you could put jumper cables on the car and get it to start would indicate a loose/dirty battery connector.
Old Jun 22, 2015 | 07:47 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I might also think that it could be a loose starter connection. Or take a look at the pic in posrt #2 of "rocketmanwpb" thread on his starter and battery replacement.
Old Jun 22, 2015 | 08:17 AM
dryadsdad's Avatar
dryadsdad
You need to check your connections at the solenoid and starter as well as the battery. I'm giving you the benefit of the doubt that you'd not re-use corroded battery cables at the battery when you replaced it.
You may need a new starter or solenoid. I'd bet starter due to the symptoms of heavy load.
Old Jun 22, 2015 | 08:24 AM
1968swbbigblock's Avatar
1968swbbigblock
Replace the battery cables when you replace the starter and the solenoid.
I have seen several that have issues with the starter lead that connects at the solenoid.
You can crimp on new ends but factory new cables and crimps are better than the ones we can make in the shop.
I would be surprised if the new starter solenoid does not fix your problem.
Old Jun 22, 2015 | 08:34 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
A 2006 auto will not have a steering column lock. If it does you have bigger issues than a starting problem. Check all of the cables as suggested. Good luck with the fix.
Old Jun 22, 2015 | 08:37 AM
myfunz's Avatar
myfunz
The first thing I would do is to see if any codes are thrown. This should give you better idea of what is going on. I would also check electrical connections below passengers side floor board check to see that all connection are tight. Always first line of defense is to first check codes then move on.
Old Jun 22, 2015 | 08:41 AM
vettephyxer's Avatar
vettephyxer
Are you connecting the jumper cables per the instructions in the manual?
To Car will not start
