Side mirror adjustment switch problem
Old Jun 23, 2015 | 08:18 PM
fogey0's Avatar
fogey0
Default Side mirror adjustment switch problem
I started having problems with the switch on the armrest in my '07. I started to have to hold the switch down on the side I wanted to adjust and the button direction at the same time to get the mirror to move. It has gotten worse to the point the left/right rocker switch is so loose I can't adjust the mirrors at all. In fact, if I pull up on it it comes out of the armrest.
Anybody have an issue like this or any idea of what needs to be done to fix it?
Old Jun 23, 2015 | 08:46 PM
EVRose's Avatar
EVRose
Never heard of this but it sounds like replacing the switch is in your future. Did you have the preferred mirror setting saved in memory?
Old Jun 23, 2015 | 08:54 PM
fogey0's Avatar
fogey0
Lucky for me the mirrors are saved in memory. Any idea where to get the switch,how much it costs, how to install it
Old Jun 23, 2015 | 11:22 PM
ChevyDave's Avatar
ChevyDave
from what i can tell , it is part #11 here in this blowup..
011 - 20794872 SWITCH. Door Window
SWITCH,SI WDO(MAS)(EBONY)(INCLS MIRROR SW) - LH
CONNECTOR-PLATE-SWITCH, Door Window. For: Y (2006 - 2007). LHD. Required: 01
CONNECTOR-PLATE-SWITCH, Door Window. For: Y (2008 - 2013). LHD. Required: 01
$86.37 Stock Code 20794872 ; 10399364
I see it listed in many places doing a Google search for that number.
**************remove/install instructions**************************** ****************************
http://www.theredlion.us/DSV%20Drive...%20Install.pdf
see #6.. https://www.corvetteforum.com/forums...ll-method.html
Old Jun 24, 2015 | 07:38 PM
fogey0's Avatar
fogey0
Great help. Thanks, much appreciated!
Old Jun 24, 2015 | 07:54 PM
EVRose's Avatar
EVRose
You can get that switch on ebay for around $65.
To Side mirror adjustment switch problem
