engine light
Old Jun 24, 2015 | 08:39 AM
rob62's Avatar
rob62
Default engine light
I had a plug wire come loose while driving and the engine and traction control light responded accordingly. Wire's reconnected but engine light stays on. Can it be turned off without tools or is a shop visit necessary? Thanks people.
Old Jun 24, 2015 | 08:44 AM
Roadstarblue's Avatar
Roadstarblue
disconnect neg side battery for 5 minutes . reconnect light will go off
Old Jun 24, 2015 | 05:33 PM
rob62's Avatar
rob62
Thank you
Old Jun 25, 2015 | 06:59 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Let us know if disconnecting the battery works. It should not. Codes would have much less diagnostic value if they disappeared just because power was lost. Disconnecting the battery was the way you reset them 30 years ago but not today.
Once an issue is fixed the light and codes will reset themselves after a given number of tests are passed. If you have really fixed the issue you can just ignore it for a few dozen cold starts and the light will go away on its own. If it doesn't go away on its own then you haven't resolved the issue and no amount of disconnecting the battery is going to fix a loose plug wire.
Old Jun 25, 2015 | 07:51 AM
RichKiss's Avatar
RichKiss
Any parts store will clear it for you if it isn't a true code. Don't forget to get the code.
Old Jun 25, 2015 | 08:53 AM
C6ToGo's Avatar
C6ToGo
A $17 CAN-enabled code reader which also erases codes is a good investment for any toolbox. Amazon has several.
Old Jun 25, 2015 | 10:12 AM
Grimlock13's Avatar
Grimlock13
It will turn off by itself after 3 start up's and drives. I had it happen to me last summer. Plug wire popped off coil.
Old Jun 25, 2015 | 10:39 AM
Seadawg's Avatar
Seadawg
And if you pay about $5 more, you can get one that will "live scan" all kinds of things on your vette, if you are interested in seeing it.
Here a link to another thread, this is the one I got last week, and I really like it for the money. This is one of many, however, that all do the job..... https://www.corvetteforum.com/forums...scan-tool.html
Old Jun 26, 2015 | 07:45 AM
rob62's Avatar
rob62
Yes, now it's off after a few drives. Thanks.
Old Jun 26, 2015 | 07:56 AM
CriticalmassGT's Avatar
CriticalmassGT
I prefer this:
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
And the Torque Pro app
To engine light
