Wiper refills
Old Jun 24, 2015 | 01:51 PM
JoesC5's Avatar
JoesC5
Default Wiper refills
A few minutes ago FedEx dropped off the wiper refills I ordered on Amazon. 12335960-drivers side and 12335961-passeger side.
They are clearly marked as GM and are in sealed plastic sleeves.
They appear to be identical.
Anyone know if they are supposed to be different(re the different part numbers) from one another?
Thought I would check before pulling the car out of the garage to install them (I can't open the hood as it's parked under a 4 post lift in my garage.
Old Jun 24, 2015 | 01:59 PM
jrose7004's Avatar
jrose7004
What do the ones on your car look like?
Old Jun 24, 2015 | 02:05 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
What year is your car? Gene Culley's website, http://www.cultragfactoryparts.com, lists two different part numbers for my 2006.
Old Jun 24, 2015 | 02:07 PM
cclive's Avatar
cclive
Mine, L and R, are the same length...you should be fine. They are about 20.5 inches long.
Old Jun 24, 2015 | 02:08 PM
JoesC5's Avatar
JoesC5
I haven't pulled the car out of the garage yet, so I don't know. It's hot out there, so I wanted to make sure I have the correct refills before moving the car and removing the old blades.
I originally thought when I ordered them that maybe the reason for two different blades(ie: two different part numbers) might be because of different lengths, but the two new ones are the same length.
Old Jun 24, 2015 | 02:12 PM
JoesC5's Avatar
JoesC5
Thanks,
Both of the new ones are ~20.5" in length.
Maybe a slightly different hardness rubber between the two?
Seems odd that GM would assign a different part number between the drivers side and the passenger side if they were the same refill.
Old Jun 24, 2015 | 02:13 PM
JoesC5's Avatar
JoesC5
2009. I got the numbers straight from my owners manual.
Old Jun 24, 2015 | 02:38 PM
cclive's Avatar
cclive
Nice thought...but I would be more inclined to figure that GM just needlessly applied two part numbers to one part. NAPA lists them the same and length is the only parameter. GM doesn't make them anyway, a supplier does...ANCO, TRICO etc.
Old Jun 24, 2015 | 03:22 PM
ChevyDave's Avatar
ChevyDave
Yep , if you look at GM's part catalog , it will show them with 2 different part numbers.
Old Jun 24, 2015 | 04:28 PM
JoesC5's Avatar
JoesC5
These are made in Japan. I don't believe they are made by either Anco or Trico. They appear, at a glance, to be identical construction to what is now on my car(original). They don't appear to be generic style aftermarket blades sold at auto parts stores, Walmart, etc.
When I purchased my Mercedes refill at my Mercedes dealer they were in Mercedes packaging but were made by Trico, and were not constructed the same as the OEM blades. When I purchased refills for my C5 from my Chevy dealer, they were in ACdelco packaging but were made by Anco, and also were not constructed the same as the OEM blades. In those two cases, it appears that the refills sold at the dealerships were made by aftermarket companies and not the OEM suppliers to Mercedes and GM.
Old Jun 24, 2015 | 04:56 PM
dbirdhouse1's Avatar
dbirdhouse1
Default Is it just me?
A. Why can't GM make wiper arms (passenger side anyway) that completely lift away from the windshield to make installing easier (like my wife's Prius)?
B. Past experience, replacement blades don't work as well as initial factory ones.......
First world problems in any case.....
Old Jun 24, 2015 | 05:22 PM
Dano523's Avatar
Dano523
FYI, you can replace just the "blades/rubber inserts" in the holder, and do not need to buy the entire blade and holder instead.
Local auto parts store has the rubber inserts part is self for a few bucks each, and easy to just change the blades once a year. As for during the year, just use an alcohol wipe or some rubbing alcohol on a paper towel to clean the blades.
As for removing the blades from the holder, squeeze the retainer hook, slide the blade out of the C holders of the are then slide the new blades back on to the holder. I will install the new blades with the Hook retainer towards the bottom of the windshield (if the arms where straight up and down, and do not remove the plastic Blocks on the refill. the hold the metal rods on the sides of the refill blade, and as you slot the blade up the C claws, the plastic blocks will slide down as they get to the end C claw, and off the blade as you go to hook the retainer into the bottom/last C claw of the arm.
Old Jun 24, 2015 | 07:06 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
The wiper blades are different on the two sides. The driver's side has a little "wing" on it (presumably to keep it pinned to the windshield at high speeds, but I'm not sure who would be driving that fast in the rain), and the passenger side is bare.
You can also replace the blades with aftermarket available at Wal Mart and auto stores, such as Bosch, RainX, and Michelin. I like the ones that have an internal spring, e.g., RainX Latitude, but they're more expensive than the OEM ones.
Old Jun 24, 2015 | 08:00 PM
cclive's Avatar
cclive
Since he said "refill", I had figured all along that he was talking about just the rubber portion of the wiper system and not any metal components. I've never seen any reason to replace metal arms.
Old Jun 24, 2015 | 08:03 PM
okie08vette's Avatar
okie08vette
I purchased a pair of PIAA wipers and they are the best I have ever used. I never saw any sense in going cheap with wipers, when you need them you want the best. It takes two minutes to swap the entire assembly but just changing the rubber blade is a PITA. IMO
Old Jun 24, 2015 | 10:22 PM
JoesC5's Avatar
JoesC5
Yep. I purchased the refills, not the complete arms. I have had poor luck with aftermarket refills over the years, so I only wanted GM OEM refills.
Old Jun 25, 2015 | 05:14 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Why would anyone want to waste money on wiper blades? It's not like a Corvette was meant to be driven in the rain!
To Wiper refills
Old Jun 25, 2015 | 05:44 AM
SpeedUp's Avatar
SpeedUp
Right? Everyone knows they blow up when they get wet.
Old Jun 25, 2015 | 11:22 AM
NoRuls's Avatar
NoRuls
Pass side GM part # 10306887
Drivers side GM part # 103068888
Paid $11.67 + tax each 3 years ago at a Chevy dealer in CT. Not a refill, the whole blade including the wind deflector
Old Jul 1, 2015 | 09:04 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
The two different numbers are for the blade and wiper insert assembly and wiper insert only.
