Check engine code po471
Old Jun 26, 2015 | 07:51 PM
JDvette98's Avatar
JDvette98
Default Check engine code po451
2008 has 17200 miles on it just had the check engine light come on buddy has a code reader came up po451 evaporative emission system pressure switch does anyone know what this means ok to drive Any info is greatly appreciated Thanks
Old Jun 26, 2015 | 10:29 PM
RicK T's Avatar
RicK T
I didn't find P0451 but did find P0454. I have no idea what the difference is so don't make assumptions. This should at least give you an idea what's involved and as suggested might be good idea to just replace the gas cap first:
https://www.corvetteforum.com/forums...ode-p0454.html
Old Jun 27, 2015 | 12:17 PM
jwf's Avatar
jwf
I have a list that shows P0471 as "Exhaust Pressure Sensor Range/Performance". I have no idea what hat means, but I hope the knowleged helps....
Old Jun 27, 2015 | 12:28 PM
HK770's Avatar
HK770
Googled this
http://repairpal.com/OBD-II-Code-P0451
Old Jun 27, 2015 | 05:59 PM
vt65's Avatar
vt65
Originally Posted by HK770
man I love this Forum! always someone here can supply the answer
Old Jun 28, 2015 | 12:10 AM
68/70Vette's Avatar
68/70Vette
I read that the pressure switch is on top of the fuel tank. That's going to be difficult to replace.
Old Jun 28, 2015 | 07:19 PM
jwf's Avatar
jwf
HK770, Thanks for the tip on that site!
Old Jun 28, 2015 | 09:58 PM
cclive's Avatar
cclive
I would check that the gas cap is on correctly as this is the simplest thing to check. You can then clear the code with a scanner or wait a few start/run cycles for it and see if it clears. It will not clear right away even if it is fixed.
To Check engine code po471
