Thanks I like them too. Almost went with drag radials on the rear but for the price it was too steep to have a tire that won't last long.
Went with stock size front tires. If I understand the tires they are 20 millimeters wider which equates to 0.7874 inches wider than the stock 325 rear tires.
Bridgestone Potenza RE-11
Michelin Pilot Super Sports
Bridgestone Pole Position S04's
Stock run flats
I will rank them in that order of preference for performance. For daily driving swap the RE11 and Super Sports as they aren't as good in the rain (RE11 worse than SS in rain). Dry weather flat out performance the RE11 are the best.
