Electrical issue
Old Jul 6, 2015 | 06:06 PM
duke corona's Avatar
duke corona
3rd Gear
Default Electrical issue
I have a short some where go over bump car shuts off hit break car starts back up, car started up with no one in it ,check codes flashing in random order on dash.
Old Jul 6, 2015 | 06:08 PM
ChevyDave's Avatar
ChevyDave
not good get fixed
Old Jul 6, 2015 | 06:57 PM
Moman01's Avatar
Moman01
Check all your grounds.
Old Jul 6, 2015 | 07:12 PM
truckplay's Avatar
truckplay
the ignition button has been known to wear out and can give you that symptom
Old Jul 6, 2015 | 08:05 PM
okie08vette's Avatar
okie08vette
The shutting off part sounds like a loose ground, but starting back up when you press the brake is strange. Will the car start just by hitting the brake when it is standing still? It must be a loose ground and when you hit brakes it force ofslowing the car causes the ground to reconnect. I would tighten all grounds and make sure the battery terminals are tight.
Old Jul 6, 2015 | 09:27 PM
duke corona
3rd Gear
Thanks for the help guys I'm still learning to navigate the site please be patient. The shop I have it at the owner told me t thanks for the help guys I'm still learning to navigate the site please be patient. The shop I have it at the owner told me that the car started all by itself with no one in it and no one around the key fob was in the cupholder his comment was your car is possessed LOL
Old Jul 6, 2015 | 10:04 PM
VET4LES's Avatar
VET4LES
I wouldn't leave the fob in the car. You never know, maybe it's defective.
To Electrical issue
