Reading Gauges with engine off
Old Jul 10, 2015 | 09:05 AM
Itshakes's Avatar
Itshakes
Default Reading Gauges with engine off
I have looked high and low, to no avail. How do you activate the gauges without starting the engine? I went out this morning, before our monthly Corvette trip, and wanted to see how much gas was in the tank. I could not figure out how to read the gauges without starting the engine. I tried to press the accelerator down while pushing the start button...nothing. I tried using the acc button....nothing. Is there some secret procedure to reading the gauges without starting the engine? What am I missing? I cannot find anything in the owners manual.
2013 GS Coupe
Old Jul 10, 2015 | 09:16 AM
Zero_6's Avatar
Zero_6
Did you hold down the acc button for a few seconds?
Old Jul 10, 2015 | 09:21 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Time to read the manual.
Old Jul 10, 2015 | 09:30 AM
ttx350z's Avatar
ttx350z
If only there was a FAQ...
https://www.corvetteforum.com/forums...post1583388987
Hold the accessory button down until it goes into full on mode.
Itshakes's Avatar
Itshakes
Default Gauges
Zero 6
Thank you!! That was the answer I was looking for!! I just went out and tried it.
1bdvet
The first thing I did! I read the manual, and could not find anything.
Old Jul 10, 2015 | 09:53 AM
Don-Vette's Avatar
Don-Vette
Bingo!! most dealers don't even know this,even the owners manual doesn't explain you must hold button.
Old Jul 10, 2015 | 10:46 AM
Kent1999's Avatar
Kent1999
Or... just push start button:
1) with clutch *not* depressed (manual trans)
2) with transmission *not* in 'park' or 'neutral' position (automatic trans)
Just another alternative. As always, foot on brake for safety.
Old Jul 10, 2015 | 11:00 AM
Zero_6's Avatar
Zero_6
Originally Posted by Itshakes
Zero 6
1bdvet
I'm glad to help.
Old Jul 10, 2015 | 01:06 PM
Cratchet's Avatar
Cratchet
Do you know how to get out if your battery fails while you're inside?
It's important.
Old Jul 10, 2015 | 06:18 PM
Itshakes's Avatar
Itshakes
It's important.
Yes! I do know about the lever next to the seats. Our salesman showed us even before we bought the car.
Old Jul 11, 2015 | 01:21 AM
WadeH's Avatar
WadeH
1bdvet
It is in the manual, but not in the section about using the push button start, where you would expect. It's actually in the section on Emission Testing and Inspection - page 3-45 of my 2008.
Old Jul 11, 2015 | 07:53 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Press the bottom of the Acc. button on the instrument panel and hold the button down for five seconds. The instrument panel, including the check engine light, will light up and the ignition will be on, but the engine will not start — if you press the bottom of the Acc. button only briefly, less than five seconds, the accessory power mode will be turned on, but not the ignition.
Hey, at least the OP tried to read the manual. Most people here don't seem to know they have one.
To Reading Gauges with engine off
