PROBLEM after tranny service ?
Reason:Brought vehicle in for rough delayed clunky shifting, slight lag,to Chevy dealer with good service reputation. Had motor oil changed and They said they would reset computer and would due a 100% tranny fluid and filter exchange wich sounded good to me. BUT when I got work order it said tranny Flush . Those two procedures I thought were differant ? Result: noticeably smoother,less delayed faster shifts,less clunky even feels a bit quicker. The bad: noticeably more of a rough shaky idle, not extreme but annoying. Also on highway: all temps and guages appear to be normal. Heres the other issue, I noticed , now at idle or sitting at a light for instance engine temp will go up rather quickly to the 220 mid way mark or slightly above, as tranny temp will go from its normal 160-180 and steadily climb to over two hundred while car is just sitting there.Oil temp was 217-225 forgot what coolant temp was, what shoulD it be ? I had exaust fuse pulled when work was performed ( you know to keep all exaust ports open) Im obviously bringing it back but would like any ideas or thoughts please.P.S. no point in debating tranny fluid changing procedures, ive already seen all of the" you should and should not flush tranny arguments. " Its irrelevant because whats done is done . Just want to know if theres a possible problem. Thanxxx
If so what year did this start for the C6.
My 08 MN6 doesn't have this....hope this is correct or my foot is in my mouth again...
Bill
I had my 2005 A4 flushed and have not got it fixed yet and it has been over a year. I am battling a P0700A code that did not exist before I had it flushed. I do hope to solve this in the next 6 weeks.
As for engine shaking at idle, either bad motor mount, or its time to pull the spark plugs, and plug wires to make sure that the plugs are clean/correctly gap'd @.040", and the wires boots have been dielectric greased and seated correctly on both the spark plugs and the coils above.
Note, the factory plugs are good for 100K, but depending on the fuel additives used, the additives can be burnt into the plugs connectors, and what you are really cleaning off instead before the 100K mark.
Liquid filled motor mount that has cracked, and the fluid now leaking out.
I would tell you to check the front of the radiator to see if you picked up dirt etc that could be blocking it. This has happened to me
Dave
I have only 50,000 on my 11 and I found a lot of junk had been sucked up there . I just gently brushed it all out .
My second place I would look as was already posted is to see if my fans were working .
My car never goes above 198-205 and I live in Georgia
... but I can hear my fans running when it's real hot especially when I pull it into the garage .
Check your fans and make sure they are running on high when it's hot. You will hear them I assure u
Dave
Like others have said, check for debris on ac condenser and between condenser and radiator. Pull air filter and radiator cover to acess.
I have found leaves, plastic bags and lots of crud in between them. I do a yearly flush and clean it 2 to 3 times during summer.
I wish I could find the acid that commercial AC pros use to spray it on there, that would really shine and clean it out but I am afraid of what it would do the the other parts.
If that's the case, then the trans fluid would warm up with the engine warming. I would be checking to be sure your fan connector hasn't fried. Turn on the AC and make sure the fans are running when stopped.
Or it can be run by bypassing the radiator and just using the cooler, in this case the engine oil temp, trans fluid temp and coolant temp all warm and cool each other to a point, most do not do this if they live where it gets cold because the in series method allows the oil and coolant in the radiator warms up the transmission fluid in cold weather.
Plus when you run them in series, it provides redundancy in case one of them fails or fails to cool as it should.
So it depends on how the cooler is run, mine is in series, transmission to the radiator, radiator to the cooler, cooler to the transmission.
