Check Engine light
Old Jul 17, 2015 | 09:00 AM
Ettev01's Avatar
Ettev01
Default Check Engine light
So I purchesed my 427 vert about 2 months ago and between vacation and work, haven't really driven it much except around town. The car had 2800 miles and now 3200 after a 150 mile round trip yesterday down South.
Car ran perfect; top down/ warm day. After arriving home and approximately 2 hours later decided to go fill it up. ( here in Ohio you never know when they'll raise the gas 30 cents a gal). Engine check light noticed while driving to the station. (before getting gas just under half a tank left). Filled it; careful to put the gas cap on correctly (was it loose when I took it off? Might have been???)
Light never went out for drive home. (about a mile or so) Started up late last night, still on.
Have a appointment at the dealer Tuesday. Thoughts?
Old Jul 17, 2015 | 09:50 AM
Orion2011's Avatar
Orion2011
If the gas cap was the issue it takes about 50 miles of driving for the CEL to go out. You can get the codes read/cleared for free at Autozone and maybe some other auto parts stores.
Old Jul 17, 2015 | 09:52 AM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
The time I had a loose gas cap and a CEL I also had a message on the DIC to check gas cap. I found that it was best to not push on the cap while tightening but pull out when it clicks and have had no more problems. The light went out after a few start cycles.
Old Jul 17, 2015 | 11:40 AM
owc6's Avatar
owc6
The gas cap issue will sometimes give a CEL only, and sometimes accompanied by the DIC msg. I've had it show up both ways.
If you have Onstar, they can also read the codes for you.
The above advice about not pushing, and to slightly pull when tightening the cap is spot-on!
Old Jul 17, 2015 | 11:48 AM
vetteguy4's Avatar
vetteguy4
Check for loose spark plug wires. Had the same problem and discovered two loose spark plug wires. Pushed the wires back on and no problem since.
Old Jul 17, 2015 | 12:18 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Didn't know that. I'll file it away for use in the future should the need arise.
Old Jul 17, 2015 | 02:53 PM
Ettev01's Avatar
Ettev01
I checked with OnStar- She told me the diagnostic test showed all normal. She mentioned the gas cap could have caused.
All wires ect..... seem fine. My 4th C6 and actually never seen that light come on b4. At least it doesn't sound like anything major. Car has warranty of course but just hate to run across issues.
Old Jul 17, 2015 | 03:18 PM
CriticalmassGT's Avatar
CriticalmassGT
Torque app and a $30.00 OBDII Bluetooth reader. Best money ever spent. Probably just the gas cap though.
Old Jul 17, 2015 | 04:43 PM
Ettev01's Avatar
Ettev01
Tell me more> Is this an iphone app?
Old Jul 17, 2015 | 06:56 PM
wayback's Avatar
wayback
Sometimes the electronics in our cars act funny. I have had 2 CELs and both cleared up with 2 quick start stop cycles. CEL is for emissions related problems only so your car won't self destruct. Lol
Old Jul 17, 2015 | 08:09 PM
owc6's Avatar
owc6
A solid CEL usually is, if it starts blinking, it's usually something serious (even if the fix is simple) that could potentially cause damage if ignored.
Old Jul 18, 2015 | 10:32 AM
vettesmith02's Avatar
vettesmith02
I had the light on when I took in for an oil change.
They told me about it, and I had them do a reading of the sensors ($100).
They are normal, but the car is fighting the gas. In their words, the gas is crap although it is 93 octane.
It hasn't come on yet since...
Old Jul 18, 2015 | 01:14 PM
mch28's Avatar
mch28
You'll need this app.
Torque Free
Or Better for $5
Torque Pro
And this adapter, or one like it.
http://www.ebay.com/itm/Mini-ELM327-V2-1-OBD2-OBDII-Bluetooth-Adapter-Auto-Scanner-TORQUE-ANDROID-US-BL-/291261648793?hash=item43d08c0f99&item=291261648793&vxp=mtr
I know there used to be a Torque app for iPhones a while back
Old Jul 18, 2015 | 02:24 PM
Zero_6's Avatar
Zero_6
Mineicame on yesterday for the first time. It's my third time pumping gas too. I did push the gas cap. I then did the above method, I hope it solves the problem. Thank y'all kindly.
Old Jul 20, 2015 | 07:22 AM
Grimlock13's Avatar
Grimlock13
Torque Free
Or Better for $5
Torque Pro
http://www.ebay.com/itm/Mini-ELM327-...648793&vxp=mtr
Get a WIFI adapter for iphones.
Amazon.com: ieGeek® WIFI Wireless OBD2 Auto Scanner Adapter Scan Tool for iPhone iPad iPod: Electronics Amazon.com: ieGeek® WIFI Wireless OBD2 Auto Scanner Adapter Scan Tool for iPhone iPad iPod: Electronics
and only $17.
The torque app and the adapter make your phone a scan tool and can display gauges for different things as well as read and clear codes.
Bluetooth doesn't seem to work well with them.
Bluetooth works great with android though.
Old Jul 20, 2015 | 07:36 AM
Dcasole's Avatar
Dcasole
Will these "wireless" readers clear codes ?
Dave
Old Jul 20, 2015 | 08:27 AM
mch28's Avatar
mch28
Dave
Yes
Old Jul 21, 2015 | 12:33 AM
Grimlock13's Avatar
Grimlock13
Dave
yep, will scan and give you both new and history codes for check engine (not airbag codes) and will let you clear them.
It will also tell you if and what engine monitors are "ready" or not. Which is very nice if you have state inspections that hook up the a computer. So you know before going for the inspection if it will pass or not.
To Check Engine light
