Old Jul 20, 2015 | 07:13 PM
TyroneMD's Avatar
TyroneMD
Default ?????
Can someone tell me what this black box is at the top of my windshield ?
Old Jul 20, 2015 | 07:16 PM
let er eat's Avatar
let er eat
Onstar
Old Jul 20, 2015 | 07:19 PM
biker1059's Avatar
biker1059
Government tracking divice
Old Jul 20, 2015 | 07:34 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by let er eat
Onstar
Onstar antenna and I think maybe also a limited amount of electronics associated with it.
Old Jul 20, 2015 | 07:51 PM
wayback's Avatar
wayback
OP you need one of these since you have the "black box".
Old Jul 20, 2015 | 08:11 PM
KnightmareCS's Avatar
KnightmareCS
Secret location to stash the hash...
Old Jul 20, 2015 | 08:43 PM
Vette_DD's Avatar
Vette_DD
Dang it! Now we've got to get the mods to ban him.
Old Jul 20, 2015 | 09:11 PM
CHJ In Virginia's Avatar
CHJ In Virginia
OnStar and XM radio antenna.
Old Jul 20, 2015 | 09:15 PM
Vette_DD's Avatar
Vette_DD
No! No! No!
The XM radio antenna has never been in that spot for any model year of C6.
The 2005 model year C6 had the XM antenna in a wart on the roof. All following model year C6s had the XM antenna in the outside mirrors.
Old Jul 20, 2015 | 09:16 PM
KnightmareCS
Old Jul 20, 2015 | 09:26 PM
Dano523's Avatar
Dano523
Onstar antenna, and will even notice that the solid black on the windshield is specific to hide the box.
smaller solid black section when the car does not come with onstar instead,
As for XM antenna, was a wart on the halo on the 2005 model, and then moved inside the side rear view mirror instead from 2006 upwards.
Old Jul 21, 2015 | 08:44 AM
not08crmanymore's Avatar
not08crmanymore
Dano523 is offline Report Post
outside sidewiew mirrors.The module itself for coupes is over the back driver side wheel well under the rug. Easily asccessed and swapped for a sirius module if so desired.Back in the day before they merged it made a difference which one you had..now,probably not so much. The black box is onstar..and yes,big brother can keep track of you with it..and in later model onstart actually shut down the car if it gets stolen and you're signed up....
Old Jul 21, 2015 | 12:16 PM
Dano523's Avatar
Dano523
Onstar module (VCIM) on the early models was in the rear hatch passenger hatch chubby area under the lid behind the carpet on the front side. On the early Z06 model since the battery was installed in the cubby campartment, the VCIM was installed under the passenger set instead. On the later models, it was moved to under the dash behind the glove box for all the models since with it mounted up in the dash behind the gloove box, not longer blocked either the power passenger seat module if such was to be installed, nor the battery location on dry sump motors.
As for the XM module, its located in the hatch area behind the carpet at the wheel hub on the hatches, and behind the center waterfall cover between the seats on the convertibles.
As for the XM module, started out as analog unit in the first C6's, and then with the Sirius XM buy out, went to digital instead. So if you need to updated the module if you do have a old analog module in the car (which will not work with XM now), the correct update module is a SIR-GM1.
http://www.onlinecarstereo.com/CarAu...FQqSaQod1K0Omg
Old Jul 23, 2015 | 12:14 PM
TyroneMD's Avatar
TyroneMD
Default Thanks !
thanks for all of the info. Now can you tell me how to stop it from falling off of the plastic tabs that hold it to the windshield. sometimes, when I am driving, after hitting a few bumps in the road. its just falls off, hanging by the wire that runs under the roof panel. very annoying !
Old Jul 23, 2015 | 12:24 PM
sftl97's Avatar
sftl97
I have the same issue, keeps falling down. I'm considering removing it entirely since I don't subscribe to Onstar, but first I need to find out what else would be affected. Read somewhere that bluetooth runs through that thing and I don't want to lose the connectivity of my phone.
To ?????
