Has anyone successfully programmed a Lear
Old Jul 24, 2015 | 12:12 PM
johnodrake's Avatar
johnodrake
Moderator
Default Has anyone successfully programmed a Lear
Car2U system in their car to a Lift Master Elite Series Opener?
Old Jul 24, 2015 | 12:40 PM
HBsurfer's Avatar
HBsurfer
Not me. Finally gave up and just have the clicker that came with the opener on my visor. I have tried intently several times.
Old Jul 24, 2015 | 01:09 PM
johnodrake's Avatar
johnodrake
Moderator
And to make matters worse, the Lear call center is closed down and the Lift Master/Chamberlain people wont help because they are competitors.
Lift Master is sending me a repeater free (just pay shipping and handling of $8 lol) to make the Home Link in the 06 work.
Old Jul 24, 2015 | 02:20 PM
cclive's Avatar
cclive
Does your Lift Master remote have "Security +" on it?
Old Jul 25, 2015 | 12:37 PM
johnodrake's Avatar
johnodrake
Moderator
Don't know. It is an Elite 8500 Jackshaft (wall mount) Where would I see the Security +?
Old Jul 25, 2015 | 12:41 PM
cclive's Avatar
cclive
On my LiftMaster, the "Security+" is a logo that is printed right on the remotes.
Old Jul 25, 2015 | 01:34 PM
USAF's Avatar
USAF
Never got mine to work on either my C-6 or wife's Caddy SRX
USAF
Old Jul 25, 2015 | 02:45 PM
johnodrake's Avatar
johnodrake
Moderator
Be nice if Lear could help out......
Old Jul 25, 2015 | 02:59 PM
Larrys60's Avatar
Larrys60
Just an fyi. The repeater works well but has no battery backup, unless they have added one. If a power failure, need to reprogram car button. Not a big effort but garage door won't open. It will open with supplied remote if opener has battery backup.
Old Jul 25, 2015 | 03:27 PM
Nomomoney's Avatar
Nomomoney
Just FYI....
With the Liftmaster door opener, you can operate your garage door(s) remotely from your smartphone, rather than going through the frustration of getting that stupid thing to work from your car.
With the "Liftmaster MyQ" app, you can open/close and check on the status of your garage doors, from wherever you receive a cell phone signal.
Here's the link:
https://www.liftmaster.com/For-Homes/MyQ-Connected-Home
Old Jul 25, 2015 | 03:34 PM
phileaglesfan's Avatar
phileaglesfan
Lear system is about useless. They will sell you a transmitter adapter for $25 per door. None of my post 07 GM cars worked with my doors. Chrysler corp cars work great stock but they didnt go cheap and use lear
Old Jul 25, 2015 | 05:44 PM
johnodrake's Avatar
johnodrake
Moderator
Good to know. We have a lot of short outages.
Old Jul 25, 2015 | 05:46 PM
johnodrake's Avatar
johnodrake
Moderator
Chamberlain is sending a repeater for the Homelink. Are you saying that Lear sells an adapter that will allow their Car2U to work with a Lifmaster opener?
Old Jul 25, 2015 | 06:19 PM
pmt67usa's Avatar
pmt67usa
Veteran: National Guard
I can't promise this will work for you but I had success with my Chamberlain garage door opener, pretty normal by putting the garage door into "Learning mode" per the instructions in the user manual.
Had significant difficulty figuring out how to open my tract's security gate but figured it out and posted the instruction on the Forum..good luck..
Old Jul 25, 2015 | 06:25 PM
hydrasport's Avatar
hydrasport
Are you set on using only the homelink on the visor or have you thought about a "flash2pass" unit?
Old Jul 25, 2015 | 07:34 PM
NVR LAT's Avatar
NVR LAT
I agree that the Homelink system is much better than the Lear, but when my visor hinge broke, it was replaced (under warranty) with a new one that had the Lear system in it. I was able to program it using the instructions provided with it. I tried to program it like I did the Homelink, and when that didn't work, I read the directions and it worked first time. Maybe I just got lucky.
To Has anyone successfully programmed a Lear
