2012 Rear Differential Fluid Change Help!
Old Aug 14, 2015 | 08:34 PM
brandon.rush1's Avatar
brandon.rush1
Default 2012 Rear Differential Fluid Change Help!
I am in the process of trying to change my 2012 rear differential fluid and the plug is covered by the rear leaf spring. After checking through the forums the only useful thing I could find was removing the two 18mm cradle bolts that hold the transmission and differential. Can someone either provide a picture of these bolts or another way to access the drain plug?
Old Aug 14, 2015 | 09:32 PM
crusher1's Avatar
crusher1
No need to remove anything. I have an 07 and changed my fluid a few years back. 2006 and up an Allen socket will work, that's what I used. 2005 models you had to use an L shaped Allen tool.
http://www.southerncarparts.com/corv...nge-pm-43.html
Old Aug 14, 2015 | 10:27 PM
gsflyer2011's Avatar
gsflyer2011
Yep no need to remove anything. Just get a socket wrench with the right size extension you will be fine. Changed mine 3 times. However get a good hand pump to fill it up. It is rather tight in there, doable but with the pump much easier
Old Aug 14, 2015 | 10:29 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
It is 8 or 10mm allen and easy to get to. Be sure to remove the fill plug first.
https://www.corvetteforum.com/forums...s-for-faq.html
Old Aug 14, 2015 | 11:38 PM
brandon.rush1
I can't fit an allen key or a 10mm socket in there. The 07 is different per the forums and there are no restrictions
Old Aug 14, 2015 | 11:40 PM
brandon.rush1
I will try and take a picture and post tomorrow, but it is impossible to fit a socket or L shaped allen key in. The gap between the leaf spring and the drain plug is about 3-4 inches
Old Aug 14, 2015 | 11:42 PM
brandon.rush1
The 2012 corvette went back to what the 05 did, but more difficult. The forum that everyone keeps linking here is out of date and not accurate for a 2012
Old Aug 15, 2015 | 10:20 AM
simplegto's Avatar
simplegto
My 2011 is easy and gets changed every 15k.
Old Aug 15, 2015 | 10:27 AM
brandon.rush1
2011 is different from the 2012
Old Aug 15, 2015 | 10:37 AM
simplegto's Avatar
simplegto
This shows how to change an 05.
This is interesting too
https://www.corvetteforum.com/forums...post1584642455
Old Aug 15, 2015 | 10:39 AM
brandon.rush1
I've tried there method and I still can't access it. Using the same tool and everything.
Old Aug 15, 2015 | 10:54 AM
NoRuls's Avatar
NoRuls
ask you're question to the Corvette Mechanic at
c4c5@thecorvettemechanic.com If he doesn't know then it can't be done! LOL
Old Aug 15, 2015 | 12:04 PM
Fly-N-LOw's Avatar
Fly-N-LOw
Default Differential fluid
Don't understand why u would even be changing it. 2 1/2 yrs old does it have high miles?
Old Aug 15, 2015 | 12:07 PM
brandon.rush1
I like to use redline fluids
Old Aug 17, 2015 | 10:03 PM
crusher1's Avatar
crusher1
Found your answer Brandon. Forum member Waveguirella has the solution
Half way down the page.
https://www.corvetteforum.com/forums...or-faq-13.html
Old Aug 17, 2015 | 10:34 PM
brandon.rush1
Thank you that looks like the allen piece of the socket. Any idea how to remove the allen portion from the socket? I also heard I should try a ball socket.
Old Aug 18, 2015 | 07:44 AM
GOLD72's Avatar
GOLD72
A trick you might employ which seemed to help a lot on the 05s is this:
Lower the rear wheels onto blocks so that the full weight of the rear of the car is back on the rear wheels. That will change the arc of the single leaf rear spring back to normal and should provide more clearance for your wrench above the spring.
To 2012 Rear Differential Fluid Change Help!
Old Aug 18, 2015 | 07:56 AM
Don-Vette's Avatar
Don-Vette
From the pics it looks like a ball head Allen socket would get in there.
Old Aug 18, 2015 | 06:23 PM
crusher1's Avatar
crusher1
Just cut a piece off an allen wrench to the size shown in the pics and you should be good to go
Old Aug 18, 2015 | 10:24 PM
Spence85's Avatar
Spence85
I have a 2013 and have been wondering how to do this as well. My car has the same problem with the rear leaf spring in the way and hardly any space at all under the drain plug. A socket sure won't fit under there. I'll try a L wrench tomorrow and see if that fits, if not I guess I'll try cutting my 10mm allen socket piece off...
