Factory Nav install
Old Aug 23, 2015 | 08:01 PM
lkingdon's Avatar
lkingdon
Default Factory Nav install
I have a 2009 Z51 convertible and was wondering if it is possible to go to a Chev dealer and get a factory Nav/entertainment system installed? If any one has done that have they had any problems?
Old Aug 23, 2015 | 08:06 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Interesting question, if you mean a current-year Nav head unit. It's double din so it might fit. Probably would cost a fortune though.
Old Aug 23, 2015 | 08:13 PM
lbzraptor's Avatar
lbzraptor
I know its not the same but I had one installed in a 2500HD truck with no problems. Plug and play and all steering wheel controls along with RSE still worked. Was around 750 with dealership doing it. Also had a 6 disc changer installed in same vehicle that was a plug and play also. So I would think it would work.
Old Aug 23, 2015 | 08:48 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We've been using the factory C6 nav for over 100k miles, and I like it. Every system has it's own advantages and disadvantages, the biggest (but not the only) plus of the GM C6 is that it will project turn/distance info on the HUD. None of the aftermarket units can do that.
But...
Last time I checked their website, GM has not released an updated nav disc since 2013, and there is no guarantee they ever will. So I wouldn't install the GM system that you might never be able to get updated maps for, unless there is some evidence of future updates.
Old Aug 23, 2015 | 08:57 PM
unclecookie's Avatar
unclecookie
I have a 2008 Z51 coupe and did the factory Nav swap. It's easy to do. My best advice is to do a search for Ray Kawal. His website has a very nice write up with lots of photos on doing the swap. He also has complete wiring harnesses if you happen to need any. After the install, the only thing you need to do is have the unit unlocked (if it is a used unit). This can be done by a dealer, or an independent shop if they have a Tech II. I took mine to a Chevrolet dealer and they charged me $129 to unlock it. They charge 1 hour minimum even though it only took 5 minutes to do it.
Old Aug 23, 2015 | 08:58 PM
lkingdon's Avatar
lkingdon
But...
So if I got the Nav system installed from Chev, the model that would have originally came with it if I had clicked that option box, I cannot get map updates for it?
Old Aug 23, 2015 | 09:00 PM
lkingdon's Avatar
lkingdon
Good advice, thank you
Old Aug 23, 2015 | 09:15 PM
Kent1999's Avatar
Kent1999
It's very straight-forward, with just a tiny bit of rewire needed.
But be prepared if you go to the dealer -- a retrofit is NOT a standard operation for them, and most likely you'll either get a "can't be done" or a $2000+ estimate.
In fact, depending on how new of radio you want to install, most people can get the upgrade done for less than $600 (including a used nav radio) in parts and an hour or so of labor. And it can be performed on any C6, regardless of trim level or original radio.
As stated, the 5-minute VIN relearn procedure must be performed by a Tech2 computer. Dealers will charge between $0 and $150 for the re-learn, depending on their mood.
Old Aug 23, 2015 | 09:30 PM
Gearhead Jim
St. Jude Donor '13
If you buy a used unit, it might come with any year of nav disc, or with none at all. Be sure to ask.
Same if you buy a new unit, which would be outrageously expensive too.
Some years used 2 discs, one for east and one for west. Later, they figured out how to get the extra data back onto one disc. You can Search for the year info.
But the latest GM C6 disc you can get from any source is 2013. Our 2005 Toyota Camry nav is similar, and there is some ability to use one disc in the other car but IIRC you may lose some functions. And I don't know if Toyota sells newer discs than 2013 for that system.
If we keep our 2009, and if GM doesn't come out with a new disc next year, I'll probably go to an aftermarket system. Double D mods on this forum has a good reputation, and they are within driving distance of us.
lkingdon's Avatar
lkingdon
Yes I just looked up what they want for a factory one up here in Canada and it is $2999, yikes, I am currently looking for a used one that someone may have because they upgraded to an aftermarket unit. When I find one I will install myself as I am quite mechanical and have rebuilt more then one car.
Old Aug 23, 2015 | 09:32 PM
lkingdon's Avatar
lkingdon
Thank you sir, I will be sure to ask as I am going to look for a used one.
Old Aug 23, 2015 | 09:33 PM
_05C6_'s Avatar
_05C6_
So what would one look for in searching for a used Nav?
Would any GM Nav for our years work? Or does it have to be Corvette only OE?
Sorry if I hijacked :-)
Old Aug 23, 2015 | 09:35 PM
lkingdon's Avatar
lkingdon
Great Question
Old Aug 23, 2015 | 09:43 PM
Gearhead Jim
St. Jude Donor '13
There are definitely some other model GM factory navs 2005-2013 that won't work in a C6.
I'd definitely buy a used one removed from a C6, and the 2005 units had some issues that I believe were fixed by reprogramming, but why invite trouble.
Some time around 2011, the factory nav got an external connection for your Ipod/Ipad/Iphone/etc. AFAIK, they can be installed in any year C6. If you don't get that, you'll need to buy some kind of electronic add-on like the now-discontinued GM Personal Audio Link (PAL) to play from other devices. Member "Kawal" on this forum knows all about that business.
As mentioned, I'm considering replacing my 2009 factory Nav with aftermarket, just to get map updates. If GM doesn't start selling newer discs, you will start out with maps that are at least 2 years out of date, and it will only get worse. Too bad, I like the factory Nav + our PAL. So far, the map issues aren't too bad. But in the years ahead...
Old Aug 24, 2015 | 12:02 AM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
I wonder why in the hell you'd even consider that with the plethora of aftermarket options available that are far more accurate and far more desirable than the factory Nav.
Old Aug 24, 2015 | 12:57 AM
Kent1999's Avatar
Kent1999
I would look for a unit specifically from a C6. There *might* be some cross-fit available, but I know for a fact that not all GM nav radios are interchangeable between car lines, even within the same year.
Old Aug 24, 2015 | 03:03 AM
lkingdon's Avatar
lkingdon
Any suggestions?
To Factory Nav install
Old Aug 24, 2015 | 03:15 AM
geewez's Avatar
geewez
I have a factory Nav on my 2007 C6 and if I had to do it all over again, I'd go with an aftermarket radio with Nav. I'm not very happy with the way the factory Nav works. I have a factory Nav on my 2009 Dodge Challenger and it's a lot better and more easier unit to use than the Corvettes. With an aftermarket radio you'd get features like blue tooth, Pandora radio, iPod input, free map up dates etc. The aftermarket unit would be cheaper cost wise than what I spent on the factory Nav option too.
Old Aug 24, 2015 | 05:05 AM
ProfessorDeath
Any suggestions?
Anything Kenwood. They feature Garmin nav and every audiophile's wet dream as far as customization.
Old Aug 24, 2015 | 05:49 AM
Welker1's Avatar
Welker1
Replaced the OEM unit in my '06 a few years ago, one of the best 'mods' I've done
