Coolant question
Old Aug 24, 2015 | 06:16 PM
1stZ06vette's Avatar
1stZ06vette
Default Coolant question
Hey just got a 06 z06 and every once n a while the "Check Coolant Level" light comes on! I've checked the level several times and it is full. I checked to see if it was just a coolant level sensor and they don't have one. Please help if u can!!!
Old Aug 24, 2015 | 07:33 PM
4SUMERZ's Avatar
4SUMERZ
It's possible that you have air in the coolant system. When the car is cold, remove the reservoir cap, start the car until it warms up. See if you get bubbles in the reservoir tank, or if the level goes down, if so add coolant.
The temperature sensor may be starting to go bad as well.
The Check Coolant Level message is triggered by an algorithm that compares the rise in coolant temperature over a given period of time.
https://www.corvetteforum.com/forums...post1578371022
Good luck
Old Aug 24, 2015 | 07:38 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Check the connection to the sensor. It might be loose or need corrosion cleaning. Had one on my c5 that got corroded - cleaned it up and problem solved.
Old Aug 24, 2015 | 07:41 PM
1stZ06vette
Would that also make my temp gauge read hot then colder then back up again? C it's usually running around 220*
Old Aug 24, 2015 | 07:44 PM
4SUMERZ's Avatar
4SUMERZ
It sounds if the temperature is fluctuating, your coolant temp sensor is bad.
Try checking for air in the system, that will also make the temps eratic.
Old Aug 24, 2015 | 07:54 PM
1stZ06vette
Originally Posted by LV2TOUR
It sounds if the temperature is fluctuating, your coolant temp sensor is bad. I
Where is the sensor located? Is it still on the driver side of the front of the motor ?
Old Aug 24, 2015 | 09:01 PM
4SUMERZ's Avatar
4SUMERZ
Yes, right behind the alternator on the head.
Old Aug 24, 2015 | 09:25 PM
65 Drivr's Avatar
65 Drivr
Default Shouldn't this be in the C7 section?
Old Aug 24, 2015 | 09:32 PM
1stZ06vette
Y when it's a c6 z06 with a LS7?
Old Aug 24, 2015 | 09:52 PM
65 Drivr's Avatar
65 Drivr
Default C7 Z06 Coolant issues
Just poking a rib...recent C7 Z06 coolant issues in the press.
Old Aug 24, 2015 | 10:01 PM
1stZ06vette
U lost me
Old Aug 24, 2015 | 10:16 PM
Not So Fast's Avatar
Not So Fast
LV2tour as always, good guy
NSF
Old Aug 24, 2015 | 10:32 PM
Cherokee Nation's Avatar
Cherokee Nation
You should replace the thermostat also...Good Luck
Old Aug 24, 2015 | 10:39 PM
65 Drivr's Avatar
65 Drivr
Default Never mind...I hope you get it sorted out
U lost me
Never mind...Apologies for wasting your time. I hope you get it sorted out
Old Aug 24, 2015 | 10:45 PM
1stZ06vette
No it's all good but thanks!!!!
To Coolant question
