Shocks & struts
Old 08-25-2015, 01:33 AM
Frank Capobianco
1st Gear
Frank Capobianco's Avatar
Default Shocks & struts
Have 08 was told shock is leaking on driver's side needs replaced chevy dealership said 1 shock is1000$ what shocks do I need & reasonable price 1st vette please help!!
Old 08-25-2015, 03:57 AM
Grimlock13
Grimlock13's Avatar
I'm guessing you have the adjustable "F55" suspension if they are quoting $1000 per shock. Easiest way to tell would be a large **** on the center console for "tour and "sport".
One of our vendors Cultrag performance has front shocks listed :
http://stores.revolutionparts.com/cu...shock-absorber
List Price: $1,035.74
You Save: $336.62 (33% off)
Sale Price: $699.12
Then install yourself or have an independent shop do it, since the dealer wants to charge you full list price.
The rears are slightly cheaper.
Left rear
Right rear
As far as I know, if you want to keep the mag ride system OEM replacement is the only choice you have.
Old 08-25-2015, 05:05 AM
Fcapocowboys1
3rd Gear
Fcapocowboys1's Avatar
Default Shocks & sttuts
Thank you, was wondering if I could go with regular shocks I do have the f55 sus. With **** in center console
Old 08-25-2015, 05:53 AM
Grimlock13
Grimlock13's Avatar
You can technically swap them out for regular shocks or even get rid of the shocks and leafs to switch to coil-overs, BUT you would need to work around the electronics so the car doesn't complain about not seeing the shock input and limiting your speed to 85 mph.
There are kits that do fool the system to allow you to run normal shocks, here is one set of simulators for $199. Then you can run any shocks you want which a whole set is less then one front Mag-ride shock or about $400.
http://www.zip-corvette.com/catalog/...category/8295/
Old 08-26-2015, 09:36 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Sale Price: $699.12
Left rear
Right rear
Thank you for the referral. I certainly appreciate it. We would be happy to help out.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
To Shocks & struts
Quick Reply: Shocks & struts
