6.2 engine flutter
Old Sep 8, 2015 | 09:12 PM
Waynes 02's Avatar
Waynes 02
4th Gear
Default 6.2 engine flutter
I have a 2010 GS auto. At speeds over 50mph and upon deceleration the engine flutters or shakes for just a split second. Been doing this for some time, does not seem to get better or worse. Has anyone had the same problem?
Old Sep 8, 2015 | 11:18 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I think I know what you're talking about ... sort of a pulsation on deceleration from speed. Mine does it and I was told that it was normal. I can't remember exactly what the cause is, but it seems it has something to do with the transmission, not the engine. Doesn't happen at speeds over 50 though, just on deceleration.
Old Sep 9, 2015 | 09:01 AM
Waynes 02's Avatar
Waynes 02
4th Gear
Thanks, I took Vette to Chevy dealer and they drove it and said they could not find anything wrong.
Old Sep 9, 2015 | 09:54 AM
KWC6's Avatar
KWC6
Thats not normal. My 08' has never done that, and mine is an A6. Good luck.
Old Sep 9, 2015 | 03:21 PM
PaulEddie's Avatar
PaulEddie
Same issue, 2013 Grand Sport, A6
Old Sep 9, 2015 | 05:36 PM
extrapilot's Avatar
extrapilot
If the trans is locked up at cruse speed in high gear, (actually the torque converter), I'm thinking that just when lifting the throttle, the converter would be de-coupling itself, and getting that slight flutter feeling through the car at that point.
Old Sep 9, 2015 | 08:04 PM
Waynes 02's Avatar
Waynes 02
4th Gear
Is this normal-I own a truck and a Ford Edge, they do not do that. Is this just a Vette thing
Old Sep 9, 2015 | 08:05 PM
Waynes 02's Avatar
Waynes 02
4th Gear
If I find out anything I will let you know.
To 6.2 engine flutter
